Question about Whirlpool ACQ102PV ThruWallWindow Air Conditioner
Our a/c does not have a valve to let the accumulated water escape and it had started to drip inside the window frame. Is there a valve that I'm not seeing?
    Novelist:
    Champion:
  • 246 Answers
There isn't a valve per say - it's usually nothing other than a hole in the back of the unit.
The idea is for the AC to have a slight slant (toward the outside) so that the condensate water can drain outside.'
Sometimes there will be a drain tube of some sort if the water needs to be diverted to a specific outside area - but in most cases the water just drains to the ground beneath the AC.
Sometimes the hole that the water drains out of - will clog up with debris, i.e. leaves or whatever - and you will need to rod it out with a screwdriver or something to ensure proper drainage.
hope this helps
Posted on Aug 05, 2010
Water dripping onto passenger side floor from the inside passenger assist handle.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Bob
Jan 05, 2015 | 2003 Chrysler Town & Country
I have ice accumulation on the bottom shelf of my freeze of my Maytag side by side MSD2957DE. There seems to be water dripping down from the back inside panel. Is this something I can fix on my own
If you have an ice maker, or water dispenser turn off the water supply to the fridge temporarily, and see if the problem still exist. The solenoid water valves on some of these models accumulate mineral deposits and don't close completely after time, thereby leaking.
Sep 19, 2014 | Maytag Refrigerators
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
Water accumulation and ice buildup
There is already a hole just remove the ac unit from the window,and it`s shell,take it outside and use a water hose to clean it out,and remove anything on the inside that may stop up the drain hole.This needs to be done every year before spring or summer.If this was at all helpful,please rate,thank you.
Jul 12, 2010 | Samsung AW0891M Air Conditioner
I have a alpha cd32 boiler,and i keep having to top the water up within the boiler,so to get hot water and heating again.i have checked for water leaks and nothing is found,however i did check the outlet...
Pressure relief valve - replace
The internal seal gets bunged up with dirt & scale and then leaks water [pressure] to that outside pipe
To avoid draining the whole system, turn off the two central heating taps on the 3/4 pipes and then operate the valve manually and / or disconnect - only a small amount of water will escape / drip to below the boiler
Replace valve and fill as before.
If you think your system needs flushing out - now is a good time
Turn off mains electricity to boiler before starting work
Mar 07, 2010 | Watts 3/4 Pressure Relief Valve
My ge top load washer will not allow cold water through it just drips out slowly. water comes out the water line but for some reason the machine wont let it through
Could be a clogged screen on the back of the inlet valve. If you have hard water and no water softener, especially likely. Turn off the water at the water, remove the cold water hose from the back of the machine and see if there is an accumulation of white crumbly material just inside the body of the valve. If so, carefully remove it, then use a screwdriver to remove the protective screeen inside the valve. It is a press fit and will come out with a little effort. Do not puncture it. Clean and reinstall, hook up the hose and turn on the water. Check for leaks and you should be back in business.
Mar 03, 2010 | Washing Machines
The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
Sep 01, 2009 | Heating & Cooling
Water drops
likely the water valve has sediment in it - preventing it from closing properly.
Change the valve - and think about an inline filter to prevent this in the future.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Whirlpool ACQ102PV ThruWallWindow Air Conditioner Logo
98 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
