Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Rx600 my black ink not working even with new ink. The rest of the ink is printing fine. I have cleaned the heads. Still not working.
  • Anonymous Aug 16, 2008
    I have the same problem but with both magenta cartridges?
  • 552 Answers
Here is a link to the Epson printer RX600 support page which has downloads of latest printer drivers for your unit.
Did you remove any type of protective material that may be on the cartridge before installation?
Posted on Apr 26, 2008
Printer no black, already went thru printer's clean printhead and even cleaned print head by running alcohol thru the ink lines
Alcohol is not the way to clean a print head. Simply run the hottest tap water into the ink inlet and print head for several seconds. Since print heads create heat to form the ink droplets needed to form a letter or graphic; running hot water will not DAMAGE the sensitive heads. Alcohol is fine for removing a film (Like fingerprints) from the surface and contacts, but not to be used internally within the head itself.
May as well get a new Black Cart now.
Feb 18, 2018 | The Office Equipment & Supplies
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
BOUGHT NEW CARTRIDGES (BLACK & COLOR) COST $70!! WILL NOT PRINT. SOUNDS LIKE PRINTING BUT BLANK PAGES COME OUT. . IS THERE A WAY TO CLEAN- UNCLOG PRINTHEADS MYSELF WITHOUT TAKING TO SERVICE MAN. CAN'T...
There are a few things you can do yourself to try and get the print heads flowing again, but they won't give you as good of results as a professional cleaning or new print head. I would say that the print head is most likely clogged if you let the machine sit for more than a few weeks without printing on it. If your last set of cartridges worked fine and then you immediately put in new cartridges and it didn't print, I would say the print heads may not be clogged but expired (no amount of cleaning will get them working again). To clean the print heads yourself first rub off any accumulated ink with a warm water soaked paper towel. As a check to see how your cleaning progress is going press the print head against a dry paper towel. You should see distinct entire lines for each color. You can then try resting the print head on a paper towel soaked in warm water to hydrate the print head. If no ink soaks into the towel at all after a few minutes the print head needs more cleaning than you can do yourself. Unless you know someone with a hand held garment steamer with a narrow nozzle on it you can steam the print head to loosen up the ink stuck in it.
Feb 03, 2010 | Brother IntelliFAX 1840C Plain Paper...
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
Epson photo 995 - black ink not printing
This is a common problem I have found with Epson printers. If you don’t use the printer on a regular basis the printer heads can clog. I have found no way to clean the heads once this occurs. I will now only purchase HP printers because the printer heads are part of the ink cartridges. With every cartridge change you get new heads, end of that problem!
Mar 09, 2009 | Epson Stylus Photo 895 InkJet Printer
Canon ip5000 won't print black
try taking the cartridge out and cleaning it then replace it after that unplug it for a couple minutes and then plug it back in and let me know what happens
Jan 17, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
One of the inks doesn't work -epson rx 620
I am, and I'd say you've hit the nail on the head non OEM or non OEM ink in the past, has traveled it's way along the system to the print head filters and clogged them, virtually impossible to clean such microscopic filters and holes, and very tricky even to get apart. The fix really is to replace print head and reprime with gen ink, not cheap if not under warranty.
You can try magic wand stuff and spin the wheel and try your luck but I never sent you OK!
search print head cleaner, ie
or my favourite bandaid, Fill the purge station with windex, let sit parked up for a day, run 20 cleans with new gen ink, and pray!
My other favs include, go to shop and buy new and dont buya non gen. inks
Nov 17, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Can't seem to print in black only.
Are ya sure it isn't only preventing scanning direct to printer output? Is it also disallowing scanning to file? Epson printers can´t operate if one of the cartridges is empty. There is no workaround for that. Epson printers actually use a LITTLE ink from ALL the color carts, even when you select "black only" in the driver. They do this to help keep the nozzles from clogging in the case of users who mostly print in black. Nobody [besides perhaps Epson] ever claimed Epson printers were the most efficient or environmentally-friendly ones in the world. for quite a while now Epson uses piezoelectric printheads, as opposed to the thermal heads used on most other printers. The enemy of piezo heads is air bubbles. They candamage the costly head, and that's why you cannot continue to use the printer if ANY individual cartridge runs out of ink. In fact, Epson designed its cartridges to signal "empty" when there's still around 15% (higher by some estimates) ink left! That's to make certain you can't run the cart completely dry and thereby introduce air into the head. If you don't believe that, carefully open up a spent cartridge over a sink, slice open the plastic film covering the various ink channels and rinse it out -- repeatedly push in the spring loaded outlet valve as well. There's so much ink left, it will take quite a while before the water begins to clear! It's incredibly wasteful and annoying, but it actually saves money in the long run, because it's even MORE wasteful to run tons of cleaning cycles just to purge the head once you've gotten air in the system. Aftermarket carts and ink can save lots of money, but they're a crap shoot. Fed up with OEM price gouging and scare tactics, I decided to try a clear-cartridge refill kit for my R200. The RX600 uses the same kit: http://www.inkjetcarts.us/servlet/Detail?no=8 Good Luck!
May 04, 2006 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
