Question about Hotpoint Refrigerators
Ice maker hose running, not shutting off when ice tray is full causeing it to over flow. What can be done? Model CSX24D side by side
  • Hotpoint Master
  • 1,606 Answers
Replace the water valve ( pt # WR57X10051 ) . This piece is what the wall water line connects to on the refrig . Also , due to the age of the refrig , I would suggest removing the ice maker ( 2 screws ) and inspecting the inside of the mold for coating disintegration which would cause water to seep thru the uncoated aluminum ( or bubbled coating ) causing the ice maker to leak , but , appear to be overfilling . In this case , replace the ice maker instead .
Posted on Aug 05, 2010
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water has stopped flowing to the ice maker but is ok to the door fountain. hoses appear to be ok.
sounds like you ice maker is shut off. There should be a switch next to ice maker to turn back on. Also look for a lock out feature for the ice maker. It could also be a sticking water solenoid to allow water to enter tray.
Dec 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker will not make ice
Well, I managed to get mine fixed. The problem was a small bit of broken plastic that runs on the cam to check whether or not the ice bucket is full. I "super glued" it back together with a "Krazy Glue" formula that says it's good for
plastic. Seems to be working now.
The hardest part was removing a small cover that hides a screw for the removing the cover of the ice maker case.
Jan 19, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Dec 31, 2006 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerators Logo
117 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
