Question about Jl Audio 12W3 Car Subwoofer
Need to know the right setting to apply for my subs
I have two Jl W-3 12's and an alpine 850 amp. i have a panasonic tv deck but im not sure what to put my settings to to get the most bass possible
  • 109 Answers
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Posted on Jun 24, 2008
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
I have a jl 500.1 and a 8w7. The sub is playing but not really it will play sometimes but most of the time i am getting almost nothing. Am i using the wrong settings or a bad connection or blown sub?
Sounds like a bad rca connection. You need both rca jacks to be plugged in from your head unit, both left and right or you will not have full power you'll have half power to your sub/subs. Check your sub with a volt meter and see what it reads. Make sure if your head unit has a sub volume make sure it's turned up. Alot of people don't realize they have a seperate subwoofer volume on there deck and it's set to low, so check that. You could have bad rca cables. If all that is ruled out(best way by trying a different amp) the amp itself might be having problems. Don't think it would be in protect mode either.
Let me know if you have'nt allready.
Nov 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Daisy Chaining 2 Mono Amps to 1 Sub?????
i beleive they have to be the same amps.an i think they have to be able to handle being strapped together.id look into getting new amps to run it elemental deisgns i know u can strap them together an controll them from the master amp.i dont think alpines handle 3ohms that good either.im going to check a few things an see if u can strap them two amps toghter.if u need more help email me bertman285@hotmail.com
Oct 15, 2009 | Alpine MRP-M500 Car Audio Amplifier
When I hook my JL W7 sub to my alpine mrd m1005
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Alpine in dash tv issue
this is the problem with the additional battery wiring. use appropriate cutout and do rewiring. make sure the Dynamo has the enough capacity to charge both the batteries. better avoid using your music system till the problem is rectified.
Aug 08, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
May 29, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Jl Audio 12W3 Car Subwoofer Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
