Question about Whirlpool LER4634J Electric Dryer
After I washed a load I put a new one in and it now won't turn back on?
  • Whirlpool Master
  • 8,220 Answers
Remove the rear cover and check for signs of lint buildup.After I washed a load - 544338e.jpgb7566ff.jpgUnplug the dryer before attempting the cleanup109d8ff.jpge2b3107.jpg2e52e43.jpg699588c.jpg578d002.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
LG washer model wm2301hw won't turn on
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
https://www.encompassparts.com/item/7814463/LG_Electronics/6201EC1006L/Filter_Assembly
http://www.amazon.com/LGE-ZENITH-FILTER-ASSEMBLY-6201EC1006L/dp/B006E7V7DW
Oct 18, 2012 | LG WM2301HW Front Load Washer
I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Describe your 24032 \ 24036 Top Load Washer Problem changed the motor coupler and now the motor won't work. washer fills up but won't agitate or spin or drain
Sounds as if your lid switch is open. You can by pas it under the control panel on the right in the back it is a the wire plug. Connect the black and brown on the switch side which will allow you to just plug a new one when or if you deciced you needed this "safety" feature. Do not put any part of your body in machine while spinning. Your welcome, Masta tech.
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Maytag top load washer won''t fill with hot or cold water.
solenid valve
may be faulty.
to test disconect from the cold side and atch to the hot side,
the solenid valve is an electronic valve that switched the water on and off its usally atched inside of the back of the machine where the hose attaches to.
http://en.wikipedia.org/wiki/Solenoid_valve
May 03, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool LER4634J Electric Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
