Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Blades wont ingage on my craftsman lawn tractor #917.274811?
After hitting a tree root, blades will not cut when I press to engage
Posted on Aug 12, 2010
Blades wont ingage
I would check the belt, the pulleys and the tension of the pulleys. Any of these could be the cause of your issue. Hope this helps!
Jun 08, 2012 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I pull the blade lever the blades do not turn. Found that the trottle wire to pto is broken. Need instructions and a diagram on how to fix it. Thanks
just wire it back together, you don't have to worry about crossing the wires up. because it's just a hot and ground for a coil to magnitize to ingage the pto clutch.
Jun 21, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades turn when not ingaged to turn
This will be due to belt drag. There is a blade brake fitted that is supposed to push brake pads onto the pulleys when the blade clutch is 'out'. If either the pads are worn, or the spring is missing/broken/dosconnected, that will be the problem.
May 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman LT 2000 riding mower
Check the motor of craftsman LT 2000 riding mower
Aug 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Apr 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
277 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
