Question about Cameras
External hard disk not detected in windows...
  • 6,826 Answers
Try to download the drivers for the digital camera for windows, and install before trying to transfer pictures over to the computer with a USB cord.
Posted on Aug 05, 2010
My Lg External Hard Disk Drive HXD7 was not detected by my Laptop. Windows 7 Home Edition 64-bit.
my Lg External Hard Disk Drive HXD7 was not detected by my Laptop. Windows 7 Home Edition 64-bit.
Please help me.
Many thanks
Antonio
Apr 13, 2011 | Computers & Internet
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
When i turn it on it has a disk read error occurred message
The Toshiba cannot find a boot disk, this problem could be caused by the BIOS could not detect the hard drive because has lost the configuration or the hard drive is faulty or the disk controller is faulty.
Check the BIOS configuration to see if it has detected the hard disk and some BIOS have a utility to test the hard disk, if this is available then run the hard disk test.
Another way to test the hard disk, remove the hard disk from the laptop and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see it as and external hard drive and you can open the folders and files the the hard drive is OK and the fault is most likely the laptop's motherboard.
If the computer cannot detect or open the files on the external USB adapter then the hard drive is faulty. The hard drive needs to be replaced in the Toshiba and Windows installed to get the laptop working again.
Aug 02, 2009 | Toshiba Computers & Internet
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External disk is not been detected
Check the BIOS setting, make sure the hard disk is set to Auto (detect) or change the settings to default settings (your BOS may not have this option) then save and reboot laptop.
If the hard disk has not been detected and/or Unable to find the operating system, it means you may have a faulty hard disk or a faulty hard disk controller or the hard disk may not be making proper electrical connection.
To reseat the hard drive, remove the hard drive and reinsert it into the laptop a few times and see if it boots up..
If it still does not see the hard drive then the fault is probably the hard disk. To test if the hard disk is faulty, remove the hard disk and insert it into a hard drive USB adapter and connect it into the USB port of a working computer. If you don't see this drive as an external drive then you will know its faulty. Then you will need to purchase a hard drive, insert it into your laptop then install the Windows operating system and all your device drivers and programs to get your laptop operational again.
If the hard drive is OK the the fault is with the disk controller, and it is near impossible/expensive to repair the motherboard. Put your money towards a new laptop and put the hard disk into a USB hard disk adapter case and use it as as a portable external hard drive.
Best of luck.
Dec 12, 2008 | Toshiba Satellite M45-S351 Notebook
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Virous in removeble harddisk
try to boot to safe mode, and see if it is detected. If it is detected in safe mode. Uninstall and reinstall any drivers that came with your external hdd. If still no go, reinstall windows. If after reinstalling windows, still not detected, replace external hdd.
Feb 16, 2008 | Microsoft Windows XP Home Edition
Cameras Logo
12 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
