Question about Maytag Refrigerators
My Maytag MFI2568AEB control panel is blinking (all lights) and the ice door is cycling open and closed. Is this a ice door, or control panel issue.
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
SOURCE: Maytag Ice2O
I concur with calling Maytag. I'm on the phone with one of their reps now and he's overnighting a new PCB free of charge. Installation is free too.
Posted on Mar 28, 2008
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
I had the same problem 4/28/08 - Called Maytag they're sending the part and repairman free.
IN THE MEAN TIME.......Maytag suggested to me to: take a phillips head screw driver and remove the hinge cover from the top of the left door. You'll find a white connector with four wires coming from each side. Disconnect the connector in the middle and the flap will stop (and so will the lights).
Posted on Apr 30, 2008
SOURCE: Maytag MFI2568AEB- icemaker flapper keeps
talked to a buddy of mine. sensor in behind the control panel is out. not the flapper. also contorl panel might be out.!
Posted on Aug 07, 2008
Still got a problem with mfI2568aeb water and ice don't work
I was wondering if maybe the ice box was in sabbath mode?
Sabbath Mode (SAb)
When the Sabbath Mode is on, all control lights,
interior lights, and the night light will be disabled until
the feature is turned off. Press the Door Alarm pad
for three seconds to restore the lights.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 21, 2010 | Maytag MFD2561HE Bottom Freezer French...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Blinking board and flaping ice door
I had the exact same problem. Maytag sent me a new main board which fixed the problem. It is pretty easy to install and is located behind the fridge behind a metal panel.
Mar 23, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
Oct 28, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
280 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
