Question about Pitco Frialator SG18S Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
  • 77 Answers
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Posted on Aug 16, 2010
  • Kitchen Medix LLC
    Kitchen Medix LLC Jul 30, 2014
    If it has a robertshaw valve with a round knob make sure when you turn the knob it stops at on and off. If you can spin the knob around and around the knob is broken and is not turning the valve shaft. Don't laugh this happens all of the time. LOL
Commercial fryer cecilware
The valve could be defective.
Sep 14, 2016 | Cecilware FMS-40 Deep Fryer
Fryer cut off but pilot stays on
You could have a weak pilot or thermopile. If the thermopile is not heated correctly by the pilot, it cannot generate enough millivolts to open the gas valve. The same is true if the thermopile is faulty. Thermopiles consist of several junctions of which only some may go bad causing low millivolt output. Millivolt output with the thermostat off and pilot lit should be around 600 millivolt, you can check with a DC multimeter set on MV across the two wires coming from the thermopile. Remember, the thermopile has to be heated by the pilot thoroughly before you will get the full millivolt reading and the thermostat must be off. Cleaning the pilot assembly is often helpful, thermopiles are inexpensive and relatively easy to change. Of course, other problems can cause this issue as well, but the above are most common.
Mar 28, 2014 | Imperial Kitchen Appliances - Others
Fryer wont lite when temp knob is turned up to 350 range pilot is lit
Observe the thermostat when set to higher temp, you should hear a clicking sound as the mechanical contacts inside closes, at this point, burners should fire up.
Thermostat can be tested by checking the continuity across its terminals (using an ohm meter) when set to a temperature higher than the oil temperature.
Also, the thermopile must be free of soot or any form of dirt and the pilot must have good flame quality, gas pressure should meet the nameplate's requirement.
Jun 09, 2011 | Imperial IFS40 Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
HI showing on digital display frialator 14ss/chhov
When high is displayed it means that the probe and controller is reading that your oil temp is 30 degrees over your set temp. Use an external probe, locate it about one inch above your probe in the tank check actual temp and compare to your set temp. If you find that it is not 30 degrees over than there may be a problem with your probe, wiring or the digital controller. With a multi meter you can check your probe resitance it should be at 942 ohms at 350 degrees.
Jan 26, 2009 | Pitco Frialator 35C Deep Fryer
IGNITION WITH PROPANE DEEP FRYER
this is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Nov 27, 2008 | Kitchen Appliances - Others
Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Nov 10, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Pitco Frialator SG18S Deep Fryer Logo
394 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
