Question about NEC ETW 16DD-2 Corded Phone (necetw16dd-2)
JUST RECEIVED A USED REPLACED NEC ETW 16DD-2. HOW DO I GET THE PHONE TO RING AT MY STATION? RIGHT NOW IT DOESN'T RING AND THE SPEAKER DOES NOT WORK?
3 Suggested Answers
  • 16 Answers
SOURCE: I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Posted on Jan 12, 2009
  • 63 Answers
SOURCE: Settings
If you have a nec electra elite system go to the operators phone and hit feature key then dial 9 #
Posted on Feb 16, 2009
Why is my display is flashing "BATTERY LOW" where is the battery located?
Look on the bottom for a door to access the batteries. If all else fails go to the manual you received with the phone and follow its instructions.
Apr 28, 2014 | NEC Electra Professional Etw-16dd-1 /...
Trying to get 2 phones to utilise speaker phone
it is very easy to utilise speaker phone ..u can speak without handset
Mar 19, 2010 | NEC Electra Professional ETW-16DC-2
On the LCD show code FDA 112 whats the meaning of ?
from the phone that is forwarde hit speaker key dial 42 should be cancel code for forwarding
Apr 13, 2009 | NEC ETJ 16DD-2 Corded Phone
I would like to know how to program numbers and recall these numbers on my phone
The Buttons must be set up as speed dial in the PBX if they are then its a simple process
Mar 04, 2009 | NEC ETW 16DD-1 Corded Phone (necetw16dd1)
Settings
Feb 03, 2009 | NEC ETW 16DC-1 Corded Phone
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
How to program a line to ring keysets
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Apr 08, 2008 | NEC Electra Professional ETW-16DC-2
Nec etw 8-2
FNC 1 toggles microphone on and off on the ETW-8 phone
Jan 24, 2008 | NEC ETW 8-2 Corded Phone
NEC ETW 16DD-2 Corded Phone (necetw16dd-2) Logo
100 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
