Question about Electric Razor Pocket Rocket Ride-on Motorcycle
No power on back wheel just a red light on the off and on switch
Try unplugging the brake wires. if this does not work, it is prob. your throttle.
Posted on Aug 24, 2010
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
Infocus 4805, wont power up remotely
the lamp has burned ot and needs replaced,
Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
Why would gould water pump red trouble light indicator come on when power switch turned back on after having been off for a few hours? Had to turn off power to pump earlier in day due to volatile elec
check and prime the pump as the light may indicate no water and so the pump will not run
foot valves leak back the water so it may need priming again
Jul 21, 2017 | Cars & Trucks
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Projector
What is the model number?
Nov 23, 2013 | Optoma Office Equipment & Supplies
My back up lights burt out and wanted 2 know what runs off the same harnest or fuse for that I have a short
Hello! The back up light circuit is stand alone...Power is fed via the back up light switch to both the left and right lamp on a Red/White wire...Ground is fed by a White/Black wire...The back up light switch receives power from a 10 a fuse ( Gauge Fuse) on a Black/Orange wire... So, 12 volts from the gauge fuse on Black/Orange...through the switch on a Red/White to both back up lights...Ground to lights via a White/Black...Using an ohm meter with power off...Set on X10 scale...check the Red/White to ground...It must read open...if you read any resistance on that wire it will blow the fuse...Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 26, 2012 | 1995 Toyota 4Runner
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
I have a 1996 Miata where the alarm system goes off no matter what I do to the secuirty switch on the steering column. It can be in the off position or on and open a door and the alarm contiues to go off....
Check wires connections in ALARM WIRING DIAGRAM
Also, its possible that this info helpfull:
- Power Lock - TO DRIVERS DOOR ONLY, See DIAGRAM
- Power Unlock - TO DRIVERS DOOR ONLY, See DIAGRAM
Keepo us updated and send comments.
Oct 17, 2010 | 1996 Mazda MX-5 Miata
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
I have a Sharp 56DR650, red power light turns off.
Engine block(color wheel) needs replacing approx $650 total
Aug 09, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
159 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
