How do you change the fuser out on an HP Laserjet CP2025 printer? Is there an easy way instead of taking the whole printer apart?
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
  • 61 Answers
SOURCE: HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Posted on Mar 27, 2009
SOURCE: hp laserjet p2055dn Replace fuser unit
That is a job by it self. If you don't want to damage your printer, I'd suggest you take it to an HP dealer pay some money and get it first checked and if so be the case that it has to change, let them change it.
Posted on Aug 18, 2009
seeker5211
  • 1089 Answers
SOURCE: Colour laserjet HP cp2025 keeps
It's normal. The printer is designed to go into a cleaning cycle to maintain good print quality. Depending on your environment It could run every 50 pages or every 100 pages. You can't turn it off or modify it.
Posted on Oct 11, 2010
Hp color LaserJet cp2025 59.c0 error how to fix it
59 errors indicate one of the motors have failed. It could be a bad motor but also a bad cartridge will overload a motor and cause the error as well. If you have spare cartridges, try changing them one at a time and restart between changes to see if the error goes away. Also if the error only happens when you start to print it might be the fuser motor.
Aug 27, 2015 | HP Office Equipment & Supplies
HP LJ cm2320 wont power on
Actually, if the manual says it's the fuser, it's probably the fuser. I haven't had this problem myself, but circuit boards coming before the fuser are not indicative of anything.
Again without personal experience with this specific part; I would suggest buying one locally rather than on the internet, open the packaging very carefully, and take it back to the store if it doesn't fix the problem.
Oct 02, 2013 | HewlettPackard HP Color LJ CP2025/CM2320...
How to open fuser in hp 3600n. paper is wrapped around fuser roll
Take the fuser out of the printer after it has cooled.
Turn the gears on the left side of the fuser, this will cause the rollers to turn and you should be able to roll the paper out.
I never rebuilt fusers, so I can't give you info on taking it apart.
Oct 25, 2011 | HP LaserJet 3600n Printer
Hi, i have cp2025 printer and it giving an error 58.04 could you please help thanks
Solution or Workaround:
NOTE: Replace the low voltage power supply before replacing the fuser or fuser power supply.
A firmware upgrade is available on www.hp.com that will solve this issue.
If the error will not clear after the firmware upgrade, replace the low voltage power supply.
If the error continues, replace the fuser power supply.
If the error still continues, replace the fuser.
Cause:
Low voltage power supply malfunction.
I hope this information helps
May 12, 2011 | HP Laserjet Cp2025n Printer
HP Laserjet CP2025 stopped printing.
First thing to do is to turn off the HP. Clear out any print jobs that are sitting on your computer print que waiting to be printed. Turn the printer back on, wait about 1 minute then try printing again. If this does not work then clear the print job again and reboot your PC. Try printing again. If still you can not print then reply here with how the printer is connected to your PC. By USB cable? Ethernet? etc.
Thanks
Jun 09, 2010 | HP laserjet Cp2025dn color Card Printer
Printer hp laser jet 4plus
you need a new fuser Its easy to change Just a screwdriver. I have a fuser for 60.00 and can tell you anything you will need to know. It should take about 4 minutes to complete. 805-520-3003
Feb 13, 2010 | HP LaserJet 4 plus Printer
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
Is it easy to replace hp colorjet 2840 fusor?
Here is a link to a short animation showing the changing of the fuser:
HP 2840 Fuser Repl
Jan 20, 2009 | HP LaserJet 2840 Printer
393 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
