Question about Watches
How do I adjust the band on a invicta calibre 9238
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Rate me, please.
Posted on Aug 05, 2010
Watch not runing model 5030
That watch is powered from a 371 button cell1 battery. It is using model 9238/1970 movement. That movement is not listed as a chronograph.
Dec 12, 2013 | Invicta Watches
I am looking for a new watch band for my Invicta Pop Lupah 2397 (turquoise). Where can I order one ? Julie
Visit the Invicta site. Their posted price list has prices for what I would expect is replacing the original watch band .
http://www.invictawatch.com/invicta/price_list
If you do not have a local delaer whom you can visit to onbtain a new watch band information on how to ship your watch to Invicata can be found here:
http://www.invictawatch.com/invicta/shipping
Mar 30, 2011 | Invicta Lupah POP 2397 Wrist Watch
Got this watch for xmas, nice. the band is too big. how do i adjust the metal band?
u can have ur watch to the watch shop they may make it short fitting on ur hand
Jan 04, 2011 | Invicta 100 Meter Sport Diver Quartz...
Nesesito new band
Go to a jewelry shop that sells watches/watch accessories, or a watch kiosk at your local mall. Either of these places should have multiple bands that will work on your time piece. If you want a specific band (as in one identical to the one that came with your watch), you'll need to contact Invicta for that. Invicta Service Center
1 Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
ph: (954)-921-2444
Jul 01, 2010 | Invicta ELITE 9225 Wrist Watch
I have an invicta reserve watch how do i remove the pins to adjust the band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please
Mar 14, 2010 | Invicta Power Reserve 1948 - 9979 Wrist...
My invicta stainless steel band has two bent pins and I was told to send back to invicta repair. Is the repair of watch band more expensive than a new watch band and who can put on new band.
Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
Apr 08, 2009 | Invicta Speedway 9223 Wrist Watch
Replacement band for the Invicta 2307
SORRY but FIXYA sells nothing .check with your dive shop
Aug 17, 2017 | Invicta Watches
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Watches Logo
430 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
