Question about Brother MFC 7420 All-In-One Laser Printer
Will only print 1 copy then says paper jam, but I think it is not picking up the next sheet of paper. I have taken the paper out fanned it and replaced it only to have the unit make 1 copy and display paper jam again.
  • 1,110 Answers
Clean the paper feed tire. If it is not picking up the paper this is the most common cause.
Just remove the paper tray completely from the machine. Now look into the port where the tray was. The tire is in the center from left to right and on the top side right at the front edge where the tray goes in. Just use a cloth and some glass cleaner or even dampened with water as we are just trying to remove any paper dust/dirt buildup on the roller. Just clean the part you can see then rotate the tire around to clean the rest. I think on this model the tire will only rotate 1 direction.
Once clean just re-install the tray and test.
Good Luck and thank you for using Fixya.
Posted on Aug 05, 2010
  • atilanotax Oct 18, 2010
    I also have the problem above. I tried the above and the problem still persist. What else could I do?
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
My brother MFC-J270w will not print - says reload paper
It sounds like you have a stuck optical paper sensor or the light path is being blocked by paper dust or toner. The paper sensor is usually a plastic movable tab that has a portion that interrupts a optical sensor. I'm not sure where it would be located on your unit, but check in the sheet metal work around your paper tray. Sometimes simply loosening it or unplugging and reconnecting the connector to the sensor will be the answer. You may try spraying compressed air around the area to clean out any paper dust or toner. That worked for me. You may wish to wear a dust mask or do this outside to prevent inhaling any paper dust or toner.
Other times one will have to replace the optical sensor. I'm sorry I can't be more specific.
Jul 07, 2014 | Brother MFC-9840CDW Laser Printer
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
255 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
