Question about Maytag 30 in. Admiral LGC1330 Gas Cooktop
I want to adjust my Admiral LGC1330AD gas cook top to work on propane. How do I proceed? I'm told there is no conversion kit, it is all adjustment.
    Sergeant:
    Champion:
  • 277 Answers
Two thing you need to do.
1) Call your gas company where you are supplied propane and ask them to set you up and they or someone who contracts for them will help you.
So you will need to replace ALL burners including the oven.
2) Call Admiral and ask them about changing to propane and if they have the products
Posted on Aug 05, 2010
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
Can a GE profile black 4 burner with down draft gas cook top be converted to propane gas? How?
Hi and welcome to FixYa, I am Kelly
Everything I am reading says this unit comes with an LPG conversion Kit. It may have been removed by the detailer / retailer that you purchased it from (when ever that was.)
The 0.0354 orfices are supposed to be in the front of the inside of the cooktop and are labeled LP.
It is a matter of removing the 4 Natural Gas orifices and installing the LP orfices and then adjusting the air-flow of the grill burner Air Shutters as shown in the manual on page 32.
The center nut has to be removed from the top of the internal gas regulator and the mini post / plunger inverted and then the nut is reinstalled.
Just note that any conversions are supposed to performed by a qualified gas technician as stated by the WARNING in the manual on page 30.
The manual is here:
http://www.hammerwall.com/tempmanuals/L0603449.pdf
The step by step instructions are in the product user guide on page 30
or you can go to this link and click on info and guides:
http://www.ajmadison.com/cgi-bin/ajmadison/JGP990.html
then download the use and care guide.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | GE Profile Nonstick Griddle for Downdraft...
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Feb 12, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Jenn Air cooktop JGD8130ADS - Propane to Natural Gas
propane has more BTU, so has a small hole, NG has a laeger hole, when i last called a plumber, all he did was remove them and drill a larger hole...i don't know what the hole size was, but thats what he did. hope this helps
Jan 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Maytag 30 in. Admiral LGC1330 Gas Cooktop Logo
133 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
