Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Ok we have a kenmore upright freezer Model # 253.26062103. We got it brand new about 3-4 years ago. It was working fine til about 2 weeks ago when the ice cream became soft and high temp alarm started going off..everything else stayed frozen. my husband checked and there was frost build up on the back wall which we decided to take evrything out of the freezer and self defrost it because we thought since the outside temp was unusually high maybe the freezer wasnt able to defrost properly. We did this and plugged it back in a few days later. We put a thermometer inside the freezer and it is only reading 20 degrees F or -5 celcius. Still not cold enough. We then replaced the electronic control panel which also houses the defrost timer and that did not help raise the temp. Alarm still going off when switched is turned on. We then decided to have a repair service out...they said it was the defrost heater, timer and thermostat, we said we already replaced the timer, so we bought the other 2 parts and replaced them. well it is still not cooling properly and we have no idea what to check next...This is costing us a ridiculous amount of money and we can't get a solution...Any help would be appreciated.
  • 5 Answers
I had the same problem and it turned out to be the sensor, a $15 part. it pretty much controls everything related to defrosting.
Posted on Aug 05, 2010
I have a Kenmore 5 freezer, model 253.9135180. It's several years old granted but was working fine until 2 weeks ago. I unplugged it because it was clicking every minute or so like it was trying to turn...
Good day,
The clicking sound is the compressor trying to start and can't. The relay is clipped onto the side of the compressor and can be removed by pulling the relay off the compressor once the retrainer clamps are removed.
You can take the relay to most appliance parts houses. They Will be more than happy to test it. If it tests bad, replace it. If not, I'm afraid it is probably an internal problem with the compressor itself, and you will need to call a qualified tech since it will take special tools to test it.
Nov 10, 2010 | Kenmore 5 cu. ft. / 142 liter Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
1,156 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
