Question about Konica Minolta magicolor 4650DN Laser Printer
Printer is saying black toner is out but i just replaced it with a brand new one from Staples
I've been having this problem and it turns out (and here's that bit that makes me look stupid) that I had been supplied with the imaging unit and not the toner cartridge so you may wish to check you've changed what it is you think you've changed. Toner carts are the top row, image units the middle and waste on the bottom.)
Posted on Sep 24, 2010
    Problem Solver:
  • 3 Answers
Black toner does not travel down to the image unit, bizhub 450
except i have to feed toner in to the image unit,before it print better.
what could have been this problem.should i replace the image unit with a new one or what ? please help,thankyou
Posted on Dec 13, 2013
My cartridge is full of toner but the printer says it needs to be replaced, how do i reset the cartridge?
You can't. The toner levels are calculated and approximated. Make sure you use genuine Kyocera toner and replace it.
Sep 27, 2013 | Kyocera 1T05JK0US0 Model TK-152K Black...
Samsung CLP-300 printer, very poor black coverage
it is most likely your OPC Black Devloper is faulty which you will get uneven print out.
you will have to get it replace on the black dev (E)
laser printer got to run once every week if not the same issue will come back again & further more if your table is uneven it will cause this issue too.
May 09, 2010 | Samsung CLP 300 Laser Printer
I have a CLX-3160FN Printer and it says that my Magenta Toner level is low How can I fix that?
Have you tried putting a shim under it to make it higher?
Seriously...If the toner is low, you have to buy a new toner cartridge to replace the on that's low. No ink toner = no print.
Visit Staples, Best Buy, etc. to buy a new toner cartridge.
Nov 12, 2009 | Samsung CLX 3160fn All-In-One Printer
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Aug 21, 2008 | Sharp AM-400 Digital Multifunction Printer
Toner life end error message after replacing toner on my mfc9440cn
I took the printer back to staples and returned it. exchanged it for a new printer.
when I brought it home, the new cartridges worked just fine. It was not the cartridges, it was the printer's problem. Thenk goodness i bought and extended warranty on the printer.
The cartridges were brand new and name brand so it didn't make sense that it could be that all 4 brand new cartridges were having a problem!
Jun 07, 2008 | Brother Office Equipment & Supplies
BLACK TONER
I assume the new toner is the same brand/model as the previous one? If you still have the previous one, can you compare them for size/fittings etc?
May 29, 2008 | Epson Aculaser C1100 Printer
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Konica Minolta magicolor 4650DN Laser Printer Logo
411 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
