SONY KV2199XFJ problem was that the volume is high when we switch on the tv, after decresing the volume then we swich off the tv again switch on the tv the same problem is remaining.
Shall I can get the schematic electronic circuit diagram of TV model KV-2199XFJ
Posted on Jun 22, 2011
How to change alarm sound on s1785 sharper image
Hello
You want to decrese the volume of alarm sound I assumes, and provides this solution.
To decrese or increase it volume.
[1] Press Mode switch. Alarm time and icon flashes on the display.
[2] Press [5] to change and select alarm volume.
LO=Soft
HI = Loud
UP = Ramp Up.
OK.
Nov 06, 2011 | Sharper Image SI785 Clock Radio
Hi my sony bravia kdl-46v4100 model is decresing sound before i use 20% volume to hear it but now i use 40% of volume. What should i do? Can you guys help me? Thanks!
It's probably a station channel, channels broadcast different picture and sound quality, therefore when changing channels this can be noticable. It is probably not a tv problem.
Jul 02, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
Increse and decrese sound contol somtimes dose not
mcdevito75 here, The volumn control can also be adjusted on the keyboard, top of keyboard or on the side you"ll see the symbols for the volume control, also there should be adjustments on your head set.
Jun 29, 2010 | LG 22" FLATRON LCD Monitor
The volume stays on high. I can lower it but, after I release the button the volume goes back to high.
I have the same problem with KV-20-FV-300. My remote stopped working and when I adjusted the volume manually, it goes to high and when it adjust it back down, it goes high again. I'm able to get the sound to stabilize by getting the volume to where I want it, and then pushing the up and down volume buttons at the same time. I'm still searching for a permanant solution though.
Mar 20, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
On my psp the sound went to blank i put the sound to full and it goes down to none by itself
It maybe because the button for reducing the volume may have been pressed too hard in the past that the button had gone in so whenever you leave the volume incresing button it starts decresing by itself.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
VOLUME CONTROL
I HAVE SONY TV MODEL 2197.WHEN I SWITCH ON THE TV NO SOUND INSTEAD OF THAT I PRESS FULL VOLUME ...
Jan 27, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Operating
pretty simple.
BUTTONS:
>|| : Play/pause. press to play/pause. press and hold to power on
+ : Plus. press to go to next song, press and hold to increase volume
- : Minus. press to go to prev song. press and hold to decrese volume
LOCK switch: locks buttons, prevents loading/erasing songs
SHUFF/NORMAL switch: switches between normal and random playback
that's about it
Jul 23, 2008 | Coby MP-C582 MP3 Player
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
