Question about HP LaserJet 3050 All-In-One Printer
When copying or printing, there is a whitish strip down the center where the rollers are. Print in this area is very faint. Thank you for any advice.
  • 1,110 Answers
Remove the toner cartridge and while keeping relatively level, shake it from side to side. Re-install and try a test print. If the light band has gone away then problem solved. It does mean that your toner crtridge is probably starting to get low on toner. 90% of the time, print quality issues on HP lasers are toner cartridge related.
Good Luck and Thank You for using Fixya.
Posted on Aug 05, 2010
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
My copies have a thin blank streak about 1 inch in on the left side. the streak is about 1/4 inch wide and goes down the whole sheet of paper
Start a print or copy, and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Clean the loose toner up with a dry lint free cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2011 | Brother DCP 1000 All-In-One Laser Printer
E-studio 45 is developing faint print generally, with some areas lighter in a mottled pattern. It has a new toner cartridge. Serviceman says he is not sure of the cause. He cleaned the inside, after...
I would call the service company and ask for another tech to look at the problem..... Yes the problem could be caused by the developer. I could also, be caused by the opc drum or the charge roller... Good Luck
Jun 11, 2010 | Toshiba e-Studio 45 Black and White Copier
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Copystar cs-c2520 i have a faded line down the center when i copy only not when i print or recieve a fax.
Either a problem with the document feeder or something on the glass. If it's faded it may just be a roller not pushing the paper onto the scanning area properly.
Jul 20, 2009 | Copystar Office Equipment & Supplies
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
HP LaserJet 3050 All-In-One Printer Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
