I have a Konica Minolta c450 copier and when I print color copies I get these lines on the copy. It's almost as if the rollers the paper is passing through may be dirty or may be they need to be adjusted. Most of the copied page looks fine, it's just 2 areas on the paper where these lines (indents) appear. Any suggestions would be greatly appreciated.
  • Gail Williams Aug 06, 2010
    Hi Daniel, I tried what you suggested but I am still getting the lines. I'm also not sure if I followed your directions completely. For instance, I didn't know what the paper dust remover was so I looked it up online to see what it looked like. I then took it out as suggested, dusted it off and cleaned the roller with a soft cloth and alcohol. I could not figure out what the transport roller was but there was another piece of machinery just above the paper dust remover that had a roller on it so I wipe it off using alcohol as well. Any more suggestions would be greatly appreciated.
    Genius:
  • 1,478 Answers
The problem is from the roller on your copier, it is either the roller is stuck with some toner or the roller is worn out. You will need to remove and clean the surface of the roller and parts of the roller, try make copy again, if still same problem, replace the roller, it is damaged. But it is advice to first clean it.
Take care.
Posted on Aug 07, 2010
  • 4,323 Answers
Hi
I am assuming that you are getting these lines only while printing color printouts. This may happen due to dirty rollers. However, it may be due to Tray 2 Pick-up Roller or due to Registration Roller. Please follow the below instructions to clean them--
Cleaning of Registration Roller
1. Open the Right Door.
2. Remove the Paper Dust Remover.
3. Using a soft cloth dampened with alcohol, wipe the Registration Rollers clean of dirt
A. Cleaning Procedure
2. Pushing the hook [1] with a blue label inward, remove the Paper Dust Remover [2].
3. Using a brush, whisk dust off the Paper Dust Remover [3].
Cleaning of Transport Roller
2. Using a soft cloth dampened with alcohol, wipe the Transport Roller [1] clean of dirt.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
  • Daniel Scott
    Daniel Scott Aug 06, 2010
    Hi
    Try cleaning the area around the waste toner collecting port. Cleaning of the Area around the Waste Toner Collecting Port---
    1. Open the Rear Left Cover.
    2. Remove the Waste Toner Box [1].
    3. Wipe the areas around the Waste Toner Collecting Port clean of spilled toner and dirt using a soft cloth dampened with water or alcohol.
    Daniel
    I followed your last instructions but that didn't seem to work either. Can you suggest anything else. Thanks.
Blank copies on a Konica-Minolta c451 copier/printer.
Black or color or both? Check the transfer roller sponge looking roller on the right side cover that opens
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 09, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Bizhub284 prints but there is no ink on paper
all colors? check the sponge looking roller right side door in correctly, check print try to catch the printer in doing a job open the right side during a job is there toner on the transfer belt across from the sponge roller. does this happen during copy does demo page and meter count page come out ok, try different file also and program pdf or web page etc.
Apr 22, 2014 | Konica Minolta Bizhub C284 Color Copier /...
Konica minolta 4690mf color streaks
replace the image unit for yellow and magenta
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 22, 2014 | Konica Minolta Magicolor 4690MF...
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
60 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
