Cars & Trucks Logo
Posted on Aug 05, 2010
89 corvette quit running found bad ecm and replaced then the comp was bad replaced so now car idles great but will not take gas runs rough and misses real bad
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 17, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1839
Points
Check the fuel injectors - seems the new fuel is messing these up...
  • Anonymous Nov 08, 2010
    last resort check pins on plug to ecm
89 corvette idles rough when warmed up
clean throttle body with carb cleaner
3helpful
2answers
1990 corvette idles rough sometimes. Sometimes it runs great when I start it up. then other times it wants to stall and I have to give it gas for a while but it still idles rough. It's either one way or...
Sounds like a clogged fuel injector.
Or worse one starting to go bad.
The problem with your car is the computer system readout is analog.
older models have a OBD-1 system and it makes finding the location of a bad injector a lot harder to find.
You could try a after market fuel additive called "sea-foam"
Most Wall-marts carry this product.
Give it a shot,I've done so myself on a VW VR-6 and talk about finicky fuel injectors!.
Worked really well for me,hope it does the same for you.
If I helped any please give me a vote.
Thanks,Gary
3helpful
5answers
1989 corvette runs rough, wants to stall even after new plugs and rotor.
i want to give you the right answer but the only thing i think of is the mass air flow sensor.
2answers
Runs very rough...like it has bad gas. had a
test an replace your o2 sensors tells the comp what ratios of fuel to air.
1helpful
My 89 corvette is hard to start when cold, idles very rough. replaced the IAC and Maf sensors and had the throttle body cleaned.replaced spark plugs, cables and distributor. had timing checked. now it...
on top or near the thermostat housing is a sensor it tells the ECM what to do corvettes run hotter than average cars 210 f i believe, i wish i could chek it hands on in '' REAL TIME" FIND A MECHANIC WITH A SNAP ON SOLIS, DONT SPEND ANY MORE $ ON IT UNTIL IT IS MONITORED IN REAL TIME
25helpful
6answers
1989 Corvette starting and idle problems
replace the coolant temp sensor, not the coolant temp sending unit
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
