Question about KitchenAid Microwave Ovens
I have gas to all appliances in my home but range will not lite. Part time reidence so range has not been used recently. Is ther a reset system? Igniters are working OK.. Tom
    President:
  • 2,702 Answers
All it needs is a spider to get into the pipe work and this will stop the gas mixing in the burner,, or a little corrosion on the jets will stop it too,
you may just have a lot of air in the gas pipe will the range light with a match? or do it just blow the match out? if so your just blowing air not a good gas mix?
Posted on Aug 05, 2010
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
I have a maytag gas range tat came with my used mobile home.We have changed to natural gas. Our problem is that the range was set for propane.Ihave the orifices but do not know which burners they go into....
playing with gas in a confined space of a caravan is deadly so have a gas fitter do the job for you as they can test the replacement and work
Oct 18, 2017 | Microwave Ovens
Need to convert nat gas to lp gas have a in the counter cook top
Most manufacturers of gas appliances offer conversion kits to make switching between LP and NG fuels for ranges, dryers, etc. relatively painless.
First, you'll need to collect the manufacturer's name, appliance model and serial numbers. Then, contact your choice of either the place of purchase, or shop the part to authorized parts resellers in your locality or internet for the correct kit and best price. Use only parts designed for use in your particular appliance.
I hope this helps & good luck! Please rate my reply - thanks.
Feb 03, 2011 | Frigidaire Microwave Ovens
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
Microwave oven turns off
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
It may be worth getting it repaired. Shop around for prices and see if it is worth your while to repair it or simply buy a new one :)
Sep 29, 2008 | Microwave Ovens
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
