Question about Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White
What is the best way to remove a Toto Aquia toilet in order to renovate the bathroom?
    Scholar:
  • 122 Answers
Here is a link to Toto's website, just click on your model number to download the instruction and installation manual.
http://www.totousa.com/Default.aspx?TabId=75&ProductId=eabca3e6-cdae-427c-bbba-416d4eb453ac&SearchId=17c723a6-5f0d-4ad7-a402-2825882dc50a&PTab=2&STab=1
Posted on Aug 20, 2010
Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Toilet flush button is broken
parts are at homedepot might have to order it. you can go on line to find parts numbers. and you can get parts in the mail. good luck and good day sawdust46
Dec 30, 2009 | Toto Aquia II Dual Flush Toilet
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
FAMILIAR WITH TOTO AQUIA TOILETS AT ALL?
Everything you need to know about Toto! Hope it helps!
http://www.totousa.com/Default.aspx?tabid=215#
Jan 12, 2009 | Toto Aquia II Dual Flush Toilet
Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White  Logo
371 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
