Question about Ricoh Office Equipment & Supplies
I HAVE A RICOH MODEL MP2510 THAT SHOWS ERROR CODE SC541. I CALLED THE NUMBER FOR THE LOCAL SERVICE CENTER I'VE USED IN THE PAST BUT GOT A RECORDING THAT THAT NUMBER HAS BEEN DISCONNECTED. HOW WOULD YOU SUGGEST I PROCEED?
  • 1,110 Answers
SC541 is a fuser heat failure. This means the fuser, which heats up and fuses the toner onto the paper, is not heating properly. Most of the time on Ricoh's this is caused by failure of the thermistor(s) which are responsible for reading the temperature of the fuser unit.
I would look in your local phonebook's yellow pages under copier service/supplies. Either find an independent servicer, such as someone listed as "services all makes and models" or look for a Ricoh, Gestetner or Savin dealer. The Gestetner and Savin makes are exactly the same as Ricoh so they may be able to help.
Good Luck and Thank You for using Fixya.
Posted on Aug 05, 2010
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Nov 07, 2014 | Office Equipment & Supplies
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Getting SC541 code on our copy machine. what does that mean?
It must be a Ricoh copier,and the model doesn't matter. This code is a fuser warm-up error, and can only be reset in service mode by a technician after the problem is fixed.
Mar 24, 2009 | Office Equipment & Supplies
Error Code SC541
The Fuser Thermister is not working properly. The Fuser may need to be replaced or the two Thermisters need to be replaced on the fuser. This is what the code is calling for. A local Ricoh tech should have these parts. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
414 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
