Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Well i got oil leaking out of my Briggs & stratton 5550 series generator, the leak is at the air filter, it seems like a fuel oil mix, im not sure if one of the rings on the piston is damaged or not. wats ur guess.
  • 58 Answers
SOURCE: I just got a used Briggs & Stratton 8550/5550
here is the link that you can view and print the owners manual from...
http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=030253_0EFS1CS_LO.pdf
please rate this answer if it helps..... :)
Posted on Sep 24, 2009
  • 342 Answers
SOURCE: I have a 5550 Watts Briggs & Stratton that
unscrew the four bolts holding it on and chek the rope has not become tangled dont unscrew the centre bolt as the recoil spring will suddenly shoot out everywhere
Posted on Apr 04, 2010
ROMOAS
  • 97 Answers
SOURCE: Genarac Briggs and Stratton Engine Family
http://www.partstree.com/parts/
hope this helps
Posted on Aug 30, 2010
  • 131 Answers
SOURCE: Neighbor has a Briggs &
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Posted on Aug 15, 2011
stewbison
  • 577 Answers
SOURCE: briggs 5550 model 030253 generator
I'll take guess here, broken ring. You did mention where it was spitting oil from? GB...stewbison
Posted on Sep 05, 2011
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Nov 23, 2013 | Briggs & Stratton 491056 492932 Briggs ...
"briggs and stratton 7kw generator will not stay running
check fuel filter . check oil level. check oil level sensor circuit for broken /loose wire. check for vent blockage in filler cap. clean air filter and make sure that the choke lever is tight enough to stay off then warm
Aug 11, 2013 | Briggs & Stratton Electrical Supplies
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
Gasoline in mixed with oil in the crankcase also oil pouring out from the valve cover. Runs rough and smokes badly. What are the possible causes?
Gasoline in the oil is indication of fuel leaking past the needle and seat when the engine is not running (also high pressure in the fuel tank). You may be able to continue to use the generator with weak needle and seat (change oil) , however you must shut off the fuel when the engine is off. Easy fix however by installing carb kit. Find model number of the engine (stamped on fan cover) and contact small engine repair shop or look on line. Do not run the engine with gas in oil. Good luck.
Jul 29, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
12hp brigg & stratton engine gas mixing with oil in engine block..when start engine runs high rpm can not idle & look like gas come out carb air cleaner overflows & flood out & stop engine...
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
Sep 17, 2010 | Parks Optical 13.5hp Briggs And Stratton...
I have a gas Yard Machine Lawn Mower by Briggs and Stratton. I cannot keep it running and it is loosing oil. What do I need to do?
May be time for a tune up. Replace spark plug, air filter, change oil and sharpen blade. You may have some water in your gas. I would check to see where it is leaking oil. It may be the oil seal on the pto(bottom) side of the engine leaking and needs to be replaced.
Oct 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
103 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
