Question about Dometic RM2852 Refrigerator
I have a Dometic RM2852 in American RV 2005. The fridge has leaked all fluid can it be repaired if yes can you suggest who and where. Thank you. Edward.
  • Dometic Master
  • 8,220 Answers
This MANUAL has addresses to service centers and gives an explanation of what is involved
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
My dometic RV refrigerator RM2852 keeps tripping my gfi switch.
At rear of fridge,remove vent cover to access wiring etc., First unplug it, then follow wires from 120VAC element to circuit board and pull connections off at spade connectors on circuit board that it is attached to. With an Ohmmeter, check for reading of approx. 44 ohms. +/- 10%. If not within range, replace the element. You should have a schematic at back of fridge to show you exactly which terminals on your particular board as well are the right ones. Also, attach AC voltmeter to terminals on board where element was attached and turn fridge on, make sure it's calling for cool, and test for 120 VAC at those terminals with fridge in AC mode. My guess is a short in the element that needs to be replaced.
Aug 30, 2011 | Dometic RM2852 Refrigerator
Not cooling in hot temps
Double check clearances around fridge, which should be zero on sides and top, as well as check baffle in stack, which should be 1-7/8" above burner. Also check door gaskets with paper (it should drag through when doors closed. Does the burner stay lit when on propane, even though temperature is increasing inside fridge?
Jun 01, 2010 | Dometic RM2852 Refrigerator
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
Ref/freezer quit working. looks like somekind of liquid in back leaked out.. fuses ok.is this repairable? motorhome Domestic RM2852
motorhome refrigerators are a different system entirely than residential style refrigerators. I would do a search for dometic, not domestic, refrigerator repair
Feb 07, 2010 | Dometic RM2852 Refrigerator
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Aug 08, 2009 | Dometic Refrigerators
Just bought a 1999 camer and we cant get fridge to turn on
If you like I will help you repair your Dometic Model Number RM2852 or click on HERE=> ALL THE ANSWERS FOR DOMETIC CAN BE FOUND BY CLICKING HERE
Thanks, Sea Breeze
Jul 11, 2009 | Dometic RM2852 Refrigerator
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
501 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
