Question about Car Audio & Video
Want to connect starsound ssw-f1-1242 flat subwoofer
2 Suggested Answers
  • 8 Answers
SOURCE: how do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
depends on the amplifier if you have a mono block amp or a regular 2 output amp if it is 2 output make sure to bridge and that means the negative to one output and positive to the other output then need to find out the rms on the speaker. the amp should have the ability to adjust it you might want to get a digital multimeter set it to watts and make sure you only set it to the RMS of the speaker because max handling should be the 1800 and usually the RMS is half the max so it should be 900 w again it depends on the amp and were the adjusting knob is and or if it has one
Posted on Nov 05, 2008
What is the Specs for Digital starsound 12" ssw-f1-1242?
Starsound 12" 2000w Subwoofer
- 700rms
- stamped slim steel basket
- dual 4ohm 2" ASV voice coil
- 40 oz magnet structure
- rubber gasket ring
- silver push terminal
Not that good of quality speakers. You would be lucky if they lasted a couple months pushing 700 watts rms.
Jul 06, 2014 | Orion HCCA 12D Car Speaker
Owners manual for ssa -s1d 7800 starsound amp
Try to locate their website, and look for it there.
Jun 05, 2014 | Audio Players & Recorders
Hi what amp do i use on my starsound ssw-f1-1242 slim sub
any amplifier u use will make the sub work ( if configured for subwoofer play)
my recommendation is that u use between 400watt rms to 1000watt rms ( the smaller the box used for the sub, the more power you can give it)
please note though that playing at high power levels exceeding manufacturers specs needs someone who knows what they are doing (when it sounds distorted decrees power)
also make sure to match the headunits output voltage to the amplifiers voltage (eg. if the headunit output is 4 volt, then make sure to adjust the sensitivity on the amplifier to be at 4 volt as well)
hope this helps and let me know if you have any other question
Jan 02, 2014 | Car Audio & Video
Hi Guys I have an Starsound SSA-4495 series amp,
seems that the amp is fried, have it repaired.
Sep 16, 2013 | Car Audio & Video
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
I need help on sound built in
u may be able to custom fir the 6x9 into the rear of the vehicle, if you don't want to do that, you may be able to fit them into the spots in the doors, but that still may be a custom job. u could always go with boxes, individual boxes that you could put on the floor on maybe on the back deck where usually the 6x9s would be located. if you dont like that idea, you might try a body shop or electronics retailer because there is definitely a way to fit those speakers in the doors or on the rear deck, it just won't be an easy job for a beginner, you have to cut holes
Aug 09, 2009 | Car Audio & Video
When i turn my infinity servo subwoofer ssw 10 on and it just blows the fuse
Then it has developed an electrical fault and will need to be repaired by a technician. Sorry to bring you bad news.
Do you mean the house fuse, or the fuse built into the back of it?
If it is the fuse in the back of it, are you definitely replacing it with the same rated fuse?
Apr 26, 2009 | Audio Players & Recorders
Counter Strike Hack error
try hacks like HOOK BADBOY open ur counter stirke then double click the hack
Jan 04, 2009 | 321studios Games X Copy (900242) for PC
How do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
Nov 04, 2008 | Car Audio & Video
Car Audio & Video Logo
269 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
