Question about Dryers
I cant get any heat and it works otherwise. What would be the problem. Would it be the thermal fuse and where is it located
  • Dryers Master
  • 8,220 Answers
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
Mo steam or hot water
Check that the temperature sensor is working correctly. If it is covered in scale or otherwise faulty it may be causing the machine to leave the heat on longer than it should. If you have a multi meter use it to monitor the resistance through the ntc (providing the machine uses this kind of temperature sensor) as the temperature rises. It should be fairly linear. Try cleaning the sensor or replacing it. Also check to see if the heat is turned off when the water reaches the correct temperature.
Dec 13, 2014 | DeLonghi Coffee Makers & Espresso Machines
Where is the thermal fuse located
11hc5mf4gil._aa160_.jpg41gaqxk2jgl._aa160_.jpgThere are several temperature related fuses (see the pictures above). If the dryer won't even start, it is usually the first one, which is located on the exhaust ductwork. If the dryer, won't heat up, it is normally one of the two mounted to the metal surrounding the heating element. Regardless, locate and test all three. Before turning the dryer back on, make sure the vents are all clear, otherwise you will get to repeat the job. None of the fuses are resetable.
Jan 19, 2014 | Kenmore 67082 Electric Dryer
Not heating
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
Kenmore gas dryer (cant see model #) is not heating up or drying ? but IS running !
First thing I would do is check the thermal fuse to see if its blown. Its located behind the back wall of the dryer so you'll have to pull it out and take the back off, It will be located on the lower left side if your facing it and be white, long and then and held in with one screw. Unplug the wires and use a volt meter to check continuity on the fuse. If you dont have a meter, just unplug the two wires, connect them together and plug the machine back in a turn it on and see if it starts heating, be careful doing this. If you still have no heat plug the wires back onto the thermal fuse and check your ignitor located in the front bottom right hand side if your facing the front. A majority of the time its the thermal fuse, a really cheap part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Kenmore 72062 Gas Dryer
Won't heat. and i cant locate the fuse
my dryer doesn't heat up to dry the clothes. The drum is running but there is no heat - the clothes remain wet. Any ideas?
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Bosch tumble dryer, model wta 4100 , no heat, otherwise all OK
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Sep 12, 2009 | Bosch Dryers
Maytag pye3200ayw will not start, jump out the thermal fuse and still wont work. Any suggestion
make sure you jumped out the thermal fuse with the white wires...... in series with the white wires on the door switch.... NOT THE ONE WITH THE RED WIRES...
Jul 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not heat,everything else works but no heat.cant find fuse
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Marvin
Marvin
