Question about Sharp LC-19AD22U 26 in. LCD TV
Princely@cfl.rr.com Sharp LC-19AD22U tv lost audio
Princely@cfl.rr.com Sharp LC-19AD22U tv lost audio over the last several days. Now there is no sound. We used to be a Sharp asc, however I am not familiar with this series of tv's. Any help would be appreciated.
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
  • 16 Answers
SOURCE: My Sharp LC-26D6U has lost Audio. How can I fix
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure. Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ?2502 Heat Kit? is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from partstore.com for $19.95. However, it?s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95, also from partstore.com. Please note that board replacement for this problem is almost never necessary, so if you?re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board. If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ?important service references? by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ?buried? under other boards. Please also refer to post # 373 at: avsforum.com/avs-vb/showthread.php?t=647174&page=13 for some ?pics? of the information detailed here. My knowledge of how to solve this issue came primarily from finding the research efforts of ?Aureius? on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy! I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Oct 29, 2009
satavlad
  • 405 Answers
SOURCE: i need to know how can i connect my Sharp
You can do it two ways, one, if you desktop has just VGA (blue,15 pin) connector, the other way, if your desktop has DVI out, then you will need DVI to HDMI cable.
Posted on Nov 05, 2009
taran_2005
  • 10515 Answers
SOURCE: LC-19AD22U displays "PLEASE WAIT" with
This is not a power supply issue. There are few other possibilities. However, kindly provide more details :-
1. Does the screen remains dark with ' Please wait ' on it or the brightness and everything is correct?
2. Do you ever seen any problem with sound ?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2010
C3742U. Where can I get a replacement power cord?
If you mean the Sharp LC-C3742U TV, the power cord is part number: QACCDA039WJPZ . Several vendors have the power cord, including Amazon.com. See http://www.amazon.com/SHARP-OEM-QACCDA039WJPZ-CORD-CORE/dp/B001DEJTN6 and https://www.partstore.com/Part/Sharp/Sharp/LCC3742U/Sharp/Sharp/QACCDA039WJPZ/New.aspx, among other links.
I hope this helps.
Dec 18, 2015 | Sharp Aquos LC-13B6U-S LCD flat panel TV...
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My Sharp lc-19ad22u HDMI port went out- we thought it was the set top box but it is the TV. Can it be repaired or is it a case of the repair costing more than a new tv? The tv is only 3 years old-very...
Yes the repair will be more than the 19" LCD TV, most of the time the HDMI circuits is part of the main board which is basically the main part of the whole TV as you can see here:
http://www.shopjimmy.com/sharp-a5z603cdh0-p-w-b-unit.htm
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 18, 2011 | Sharp LC-19AD22U 26 in. LCD TV
I need to know how can i connect my Sharp LC-19AD22U 19 in. to my desktop pc
Nov 05, 2009 | Sharp LC-19AD22U 26 in. LCD TV
Lc-19ad22u
where do you live?
is it connected to to RF or AV
Mar 12, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC-26D6U sound issues
Capacitor is what I found out.. (Supposedly althoug Ive not verified).. If you can send here I'd love to see the unit...
(Theres a reason)....
Ken
Dec 27, 2007 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-19AD22U 26 in. LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
