Question about Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment
I need to replace the cutting cord of an ALKO LT250 petrol strimmer. I need to follow instructions but have no manual.
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Ryobi petrol strimmer model RCT 2800 refuses to start
Has anyone got a spare cord Pulley for a Ryobi RCT 2800C . The engine seized but I have freed it and now see the plastic spines are damaged on the pulley. I understand the part no is Hayter 683856.
Nov 07, 2008 | Garden
Poulan/Weed Eater No. 5000p 952711612 Pole Pruner Attachment Logo
294 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
