Question about Kenmore Refrigerators
Refrigerator coils keep freezing or icing up. Have to manually defrost coils with hair dryer and then it runs great for 2 or 3 days and then the problem comes back again
  • 55chevydon Aug 05, 2010
    where is the defrost timer located
    Guru:
  • 1,524 Answers
Change the defrost timer.
Posted on Aug 05, 2010
  • Robert Moller
    Robert Moller Aug 08, 2010
    Make and model number will narrow it down.
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
The coils in the refrigerator keep icing up. I defrost it with a hair dryer and they freeze up again in a day or so.
defrost timer might not be defrosting evaporator or you could be low on refrigerant, if so call refrigeration tech.
Apr 01, 2015 | Refrigerators
Permanent ice on back side of fridge near the sensor (thermistor?)
Hello Paola! If your refrigerator is frost free, that is an indication the ice build up is caused by a failure for your defrost circuit. This circuit is made up of a defrost heater, defrost thermostat (both in freezer section behind the inner shield) and either a defrost timer (if your unit is older than 5 years) or the control board if younger. If you take off the shield in the freezer and the evaporator coil is coated in ice that is probably the cause. To check, defrost the unit by unplugging, and then use a hair dryer or heat gun to defrost all the ice off. NOTE: Be ready to deal with the massive amount of water from this defrost or you will have a mess. IF I am right, the refrigerator will start working normally for 2-3 weeks (depending on your humidity it could be shorter). Then you will get another ice build up and it will do the same thing.
Jan 16, 2012 | Refrigerators
Motor runs continuaslly and freezer is not freezing also ice is building up on coils
You probally have a failure with the defrost circuit. Its function is to periodically defrost the coils. Typical failures are the defrost heater, thermostat and timer if used with this model. Take a hair dryer to the coil to melt the ice, then check with a meter if the defrost heater needs to be replaced.
Aug 23, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
The freezer keeps freezing the coil in the back of the freezer how do I put it on defrost
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Take care....
Aug 15, 2010 | Roper Refrigerators
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The coils in the freezer compartment keep freezing over causing the refridgerator temp to rise
Most times the defrost heater and defrost thermostat need replaced. manually defrosting, removing rear panel in freezer, unplugging power from wall and using a hair dryer to remove the ice allows you to visually see th defrost heater burned out. I will get some photos and links and return soon, Thanks Sea Breeze
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Model ED5HHAXVQO2 REFRIGERATOR IS NOT COOLING. THE FREEZER IS NOT FREEZING BUT IT SEEMS TO BE BUILDING UP FROST.
Sounds like your auto defrost is not running long enough to melt the ice that develops on the coils. You can easily fix this problem by using a hair dryer and removing the back panel in the freezing unit to reveal the coils. Once this panel is out use the hair dryer to melt the ice. Once the ice is cleared this should restore air flow across the coils. Hope this helps. Good luck.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer wont defrost and refrigerator is to hot
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Jul 20, 2009 | KitchenAid KSRG25FK Side by Side...
Bottom not cold enough
did you remove the back freezer panel ? if not need to
is there a large anmount of frost on the coil behind the panel?
if there is thaw the coil with a hair dryer
if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
May 17, 2008 | Kenmore 21.7 cu. ft. Top Mount...
Refrigerators Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
