Question about Canon NP 6050 Copier
E020 - Canon NP 6050 Copier
    Problem Solver:
  • 10 Answers
Just check your toner assembly
Posted on Aug 14, 2010
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Canon NP 6050 copier Error
E020 is a toner hopper motor error. This means that not enough toner is being sent to the developer box. It usually is a hard error, meaning that the part has to be changed.
Jun 30, 2008 | Canon NP 6050 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon NP 6050 Copier Logo
old marine
old marine
