Question about Cell Phones
My phone vibrates once and ends , the vibration is so light
  • Cell Phones Master
  • 17,130 Answers
Since you have not mentioned the model I will give a generral answer. Make sure that you have chosen from the phone settings the mode of the ******** to be continuous with the ring tone or only the vibration. If this is ok then you must check the ******** for fault. Open the panela nd get acess to the main board. the ******** is a tiny motor fitted with a counter weight which can be easily tested with a very low voltage even from an analogue multimeter. If this test runs the motor slowly change or else you have a fault onthe main board which need ffuther probe from the trigger switch. So check this out or take help.Hope you try carefully with the right tools. Good day
Posted on Aug 05, 2010
3 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: Stop the Vibrating
Sounds like the phone may have gotten wet. Check behind the battery for a white circle sticker, it will be red if the phone has gotten wet. Best of Luck.
Posted on Sep 25, 2007
sdowney83
  • 62 Answers
SOURCE: vibration only vibrates once
You will have to change the ringer under sound settings to "Vibrate and Ring", it is currently set on "Vibrate Then Ring".
Hope this helps,
Simon.
Posted on Nov 19, 2008
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
How to switch on nokia 0434
Nokia phones usually have one of two ways to be turned on/off. Some models are turned on/off by a dedicated button on the top corner of the phone, and others by the red "end call" button. Press and hold the button until eiother the phone vibrates once or the screen lights up
Hope this helps.
Sep 21, 2011 | Cell Phones
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
My phone is set on vibrate but it wont vibrate
the phone if in vibration mode does no mean that it vibrates.once see the settings and check whether the vibration option is set on or not.if it is off then on it then the phone vibrates
Nov 15, 2010 | Samsung Gravity SGH-T459 Cell Phone
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Vibration only vibrates once
Hope this helps,
Simon.
Oct 23, 2008 | LG VX8300 Cellular Phone
P1i continuously vibrates
my p1i continouously vibrates, what can i do
May 01, 2008 | Sony Ericsson P1i
Vibration wont work
All I did was wait for it to come back. I think it might have had something to do with the battery being low. However, that's never happened to me when the battery was low. When I plugged my charger in, I got a text message. I had the ring on high and vibrate. It vibrated for a second, then it just continued to ring. Once my phone was fully charged, the vibration came back. I think it was just a glitch in the phone. Razr's suck.
Mar 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Vibrating won't stop
hi if u find that problem just hit once back of ur phone in ur palm hit smoothly....
Jan 13, 2007 | Nokia 3230
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
