Question about Electric Mobility Tuffcare Challenger Dx 1500 Electric Wheelchair
Where do you get battries - Electric Mobility Tuffcare Challenger Dx 1500 Electric Wheelchair
    Novelist:
    Champion:
  • 232 Answers
Try Batteries Plus, Battery Warehouse or Interstate Batteries. You can also contact a local Durable Medical Equipment provider or a small engine repair shop. Check your owner's manual for the battery type but MOST LIKELY you will need a U1 12 volt 33 amp battery and you will need 2 of them. CHECK YOUR MANUAL OR CURRENT BATTERY CASE TO BE SURE.
Posted on Oct 20, 2010
What cause battry to die over night?
If test light is a 12 volt light tester AND ILLUMINATES BRIGHT it shows that a component is actively trying to complete a circuit and yes drawing power causing a drain on your battery, now if test light illuminates low, possibility could just be ecm memory or antitheft system active . either way this test should only be done with a 12 volt test light as if you use a 5 volt (computer friendly) tester , false light will have you chasing a ghost. trust me. that trick helps by checking for parasitic draws a 12 volt tester does not illuminate when keep alive memory voltages are present . those voltages are not enough to drain over night. good luck
Nov 28, 2017 | GMC Cars & Trucks
What cause the battry light to stay on when driving?
The battery is not charging. Check the drive belt is not slipping, otherwise it could be an alternator fault.
Nov 03, 2016 | Cars & Trucks
Why are my battry light staying on?
does it stay on when you have driven the car for a few minutes? if you did not drive it , try that
Nov 03, 2016 | Toyota Cars & Trucks
Phone full battery but wont turn back on
may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Nov 03, 2013 | Samsung Galaxy Pocket
Dell latitude e6400 laptop bios override password needed
u can easilyn remove the bios password by removing cmos battry for abt 3 to 5 mins and in a laptop the laptop battry itself cointains cmos battry so u just need to take out battry and then switch ont the laptop without battry then insert the battry and switch it on again good luck
Jul 09, 2012 | Dell Latitude E6400 Laptop
I have a 96 s10 blazer with a 4.3 starts hard idles rough wants to stall has misfire and when I turn on the blinker the battery gauge moves with it and when in park if I Rev the motor the speedometer and...
Have you checked the voltage at the batry when running? Sounds like alternator is not working properly. The battry is only used for starting, once started the alternator runs all the accesories & charges the battry. If not chargeing the vehicle will **** battry power. You may have a good battry surface voltage but a bad battry. The battry should be load tested as well.
Jun 24, 2012 | Cars & Trucks
Battrie start smoking and boiling the water in battries.
Check alternator output voltage. Probably overcharging.
Apr 03, 2012 | 2003 Dodge Caravan
The car want crank all the way on, it has not been driven for a year.
check to see if the battrie is full charge most likely the battrie is dead charge it for two or three hours if it dosent start the battrie is probley bad , clean the battrie termnails or if you have jumper cables jump it if it starts let it run for 20 minutes shut it off and try to start it if it dont start most likely the battery is bad
Sep 08, 2011 | 1989 Toyota Supra
Electric Mobility Tuffcare Challenger Dx 1500 Electric Wheelchair Logo
94 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
