Question about Refrigerators
Ice is forming in a patch above the bottom shelf on the left side back wall
  • 11,800 Answers
Depending on the type and model of your refrigerator, the ice should be melted by either the normal flow of air inside the unit (in that case make sure nothing is blocking it and especially that nothing is touching the back panel)  or by a resistor embedded in the back panel - in that case the resistor must be checked and that is a job for a pro - the back panel must be removed and the electric contacts tested.
Posted on Aug 05, 2010
  • rswebber397 Aug 05, 2010
    Is there a vent that could be blocked, the shelf has nothing but normal stuff on it, but it seems to ice up in that spot consistantly.
  • Azrael SRL Aug 05, 2010
    Yes, a blocked vent can definitely cause that, but you are the only one who can see if that is true: take everything out of the fridge, get in and using a flashlight and a little mirror look in all for stuff that would block one of them - dirt, pieces of paper leaves, whatever was small enough to get in there.
    But the ice might also be from what is on that shelf - ice is nothing more than the humidity from the food that evaporates and freezes to the cooling wall; if there's consistently more ice in one region it could also be because there you are putting something that has a lot of water in it. The only way to test that is to stop putting that stuff there. Put it somewhere else and see if the ice patch changes location.
Where is the defrost drain
Back behind the metal "wall" at the rear of the freezer, there is a raised "shelf" with the drain in it. Pull our freezer racks or shelves, remove a few screws, renove sheet metal "wall", and you will find it at the bottom there.
Jul 22, 2014 | Maytag Refrigerators
Ice forming inside freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Maytag Refrigerators
My refrigerator has temperature a problem. The top shelf is about 60 degrees and the bottom shelf has ice on back wall and partially freezes food.
open the door,push in the two switches on the top,the lights should go out and the fan on top should be blowing,you can remove the light cover to see the fan,if the fan isn't working cold air will stay at the bottom and the top will be warm.if there's an ice block just on the left side back wall around 2 feet up from the crisper draws then you have a freeon leak in the coil and it has to be changed but it sounds like theair isn't ciculating,bad fan motor.
Mar 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice forming on the panel on the back wall and temps 40-44 on the top shelf but freezing on the bottom shelf
Improper air flow is your problem, Defrost it first. Then make sure that the fan inside is running, if it isn't, replace it. Repairclinic.com will have what you need, just search with your model number. Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Kenmore 57029 Side by Side Refrigerator
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Ice forming on bottom of freezer section
The freezer should have a drain hole for the defrost water to flow through. This will drain into a pan outside of the freezer cabinet. If this drain tube becomes blocked it will not allow the water to drain out and it will accumulate in the bottom of the freezer section. You will have to verify that the drain is clear through to the drain pan. this can be done carefully with a piece of stiff wire. There should also be some sort of a water trap on the drain tube to prevent air from entering the freezer compartment through the drain tube.
Mar 09, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
