Question about Texas Instruments TI-84 Plus Calculator
What should I do if my calculator won't turn on?
  • kakima Aug 05, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
    Does that do anything?
  • just_bamz Aug 06, 2010
    i have do it, and it's still not turned on..
  • Texas Instru... Master
  • 8,073 Answers
The first part of the post is inserted for completeness (and in case you need to readjust the screen). You can just skim through it.
Part A or B will reset the memory. Please read the whole post before attempting the procedures described here.
The first diagnostics you should perform are:
  1. Make sure batteries are good and inserted correctly, respecting the polarity diagram: Yes, I myself made this mistake and it must be ruled out before doing anything else.
  2. After a change of batteries, the screen contrast can change: It may become too dark or too light. If it is too dark, you would not think about a malfunction because you see something on the scree. BUT it the screen is too light, it is easy to conclude that there is a malfunction because you do not see what the calculator is doing after you press a key.
  3. So, the second measure is to adjust the contrast. Press [2nd] key and Release it. Then Press and HOLD the UpArrow until screen is dark enough.
  4. A third easy measure is to use the TIConnect software (available on education.ti.com) to retrieve the device Info, and if calculator is recognized to reinstall or update the OS. You need a TI USB SilverLink cable.
Here are some more procedures to perform in the order they are presented. Please read the post till the end.
A
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. the calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
B.
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary. (see above)
C.
This step requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. the calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI web site.
  • An I/O cable to connect two calculators through their I/O ports.
Posted on Aug 05, 2010
  • k24674 Aug 06, 2010
    Sorry but I do not quite understand your comment (if it is directed at my post.)
    To which part of my post does the "it" in your " i have do it" refer to. If adjusting the contrast does not show anything, you should try one of the other procedures my post describes.
My calculator won't turn on the batteries are fresh plz help
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2013 | Office Equipment & Supplies
Batteries won't work
Aug 31, 2012 | Texas Instruments TI-83 Plus Calculator
My calculator just shut off while i was using it, i replaced the triple A batteries but now it still won't turn on, how can i fix it?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the 2ND key. Press and hold the + key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Mar 15, 2012 | Texas Instruments TI-89 Calculator
Won;t power up at all. New batteries but I did not replace back up battery. should I? Tried the contrast fix. Son said he dropped it and it got kicked down hall at school. One year old. Any hope?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
I put in fresh batteries but the calculator won't turn on.
Regards.
Sep 13, 2011 | Texas Instruments TI-83 Plus Calculator
No display at all, does not seem to be turning on, yes I replaced the batteries.....any thoughts?
Regards.
Sep 12, 2011 | Texas Instruments TI-83 Plus Calculator
My student's ti nspire won't turn on. They have the 84 face plate on it.
Put in new batteries and try again.
Regards.
Sep 12, 2011 | Texas Instruments TI-Nspire Graphic...
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
Won tturn on
Having received no response in over a month, I assume this is no longer a problem.
May 08, 2010 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
136 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
