Question about Neff Microwave Ovens
I have a Neff ceramic hob model T1722NO. It keeps switching off at anytime during use sometimes 2 seconds sometimes its ok. All the elements work ok, so its not one particular element when it switches off. It will not start again unless i switch it off from the wall switch or if i run my finger across all the controls. I have never had this or any other problem with the hob. Its about 15 years old. Many Thanks.
5 Suggested Answers
  • 119 Answers
SOURCE: GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Posted on Feb 20, 2010
  • 234 Answers
SOURCE: I am not getting power to the heating elements.
Maybe you should first by checking the fuse to the unit.Look around where the power cord come into the unit.The fuse may be blown.
Posted on Mar 15, 2009
  • 8909 Answers
SOURCE: Replacement ceramic hob element C00228943 for
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Posted on Dec 24, 2010
SOURCE: Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Posted on Apr 13, 2012
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 27, 2013 | GE Microwave Ovens
Neff b6774 turn microwave on but in switches off asfter 2 seconds heard it could be the fuse. how dfo i change it
You could have it checked by a professional technician, (the fuses are INSIDE the microwave), if you have electronic skills you can check them yourself but you need to open the oven to reach the fuses !!!REMEMBER TO ALWAYS UNPLUG THE POWER CABLE!!! before any attempt to open the oven, (to avoid all risk of electrocution) than look for ceramic german type fuses and check them with a multi-meeter, it could be a defective SAFETY SWITCH in the door latch as well... there are usually 3 switches or more, again you can verify the switches with a multi-meeter...
Jul 07, 2011 | Microwave Ovens
Sparking at the ceramic bush just above the microwave stirring blade on a neff h7871 built in microwave
If the ceramic bush, that is a good insulator of electricity, is arcing. Maybe it needs cleaning.
Apr 04, 2011 | Neff Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Microwave Ovens Logo
172 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
