Best Solution
posted on May 30, 2008
Hmmm i think i need a bit more info... have you tried using the copy function? Check the Lcd screen for error msgs? If the copy function works and there are no error msgs then i would suggest a uninstall and then reinstall of the driver:
Use this updated driver direct from lexmark. During the install it should print a test page.
http://search.lexmark.com/printer/US/en/17K0000
If the test print does not work then try a different usb port.
Hope this helps..Good Luck please rate my response..
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Lexmark X5150 All-In-One InkJet
Email this problem
Email this problem
Can you Help with these Printers problems?
Lexmark X5150 All-In-One InkJet Printer
lexmark 5150 printer
printer pulls paper *******... Answer This...
scanning to email
scanning to email
attempting to scan to enything,... Answer This...
Lexmar X5150 Printer whit...
I have a lexmark x5150 printer,... Answer This...
Trying to install x5100 series...
I keep getting an error stating... Answer This...
Repair Service
Find Printer Repairman Near You:
