BIOS flashing problem. Latest BIOS from Biostar site is on flash drive, F12 during POST opens the flash screen, file is selected; but then the process hangs at blinking message "Reading file, please wait", never gets to the actual command to begin the update. I have let it sit there "reading" for more than 5 minutes, and nothing further happens. Before attempting flash, I reloaded optimal default settings in BIOS. Any suggestions?
    Problem Solver:
  • 8 Answers
Check the manual, see if there is a jumper needs to move.
Posted on Sep 03, 2010
  • 4,737 Answers
If I am right, writing Bios files isn't possible with your Motherboard Bios Flash Memory. I've done updating bios on many motherboards, but most of them can't be written, when I contact the manufacturers, they only say that I must have done something wrong, following the instructions, but with the same instructions and procedures, it worked on some motherboards. Not all motherboards support flashing bios, since some bus and flash memory are faster and some are not. Sometimes your pendrive (flash drive) creates this problem, so I would suggest you to use another flash drive. I hope you did format the flash drive before you write the Bios updates files, if not, you should do it and you have to write the files on an empty drive.
(This isn't a solution, only an assistance, if this doesn't help, you can still ask for another expert's help)
Good luck.
Thanks for using FixYa.
Posted on Aug 05, 2010
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
How to update bios on acer aspire 4752?????
go to the acer web site, they'll have the bios and the instructions.
follow them precisely as this is a good way to screw up your laptop. but if you do it correctly, it's not terribly hard and has real benefits.
use the support link or download link, find either bios or your model and then the other.
I wouldn't suggest using any beta bios as they sometimes need to have bugs worked out first.
if you do decide to update the bios
Connect a USB flash drive to the USB port on your Acer. Send all of your files and folders to the flash drive for backup purposes.
Take out your flash drive and reboot your machine. Continue to press "F2" on your computer until your BIOS screen comes up. Check the version of BIOS that your laptop contains, write it down and then reboot your machine.
Go to the Web page for Acer support (see Resources). Click on "Drivers and Downloads" and then "Netbooks."
Click "Aspire One" and click the link for the type of Aspire One computer you own. You can locate this data in the documentation that comes with your Acer.
Click "BIOS." Find the latest BIOS version from the download list.
Click on your "Download" link. Right-click this item and then select the "Extract Here" option. When it finishes the extraction process, double-click on your "WinPhlash" file.
Click your mouse on "Browse." Go to your BIOS upgrade folder and click on the file that ends in .wph. Click your mouse on the "Open" option.
Click on "Flash BIOS." Reboot your machine and then push "F2" repeatedly to start your BIOS.
Push the "F9" key and then "Enter." Reboot your Acer to finish the process
be very careful any mishap can totally screw up your computer and make it unuseable
hope this helps
Aug 22, 2012 | Acer Computers & Internet
I need to update my bios
Updating bios just for the sake of it is a dangerous practice. If your system is not having any problems then leave it alone. If you do have problems such as inability to recognize a larger harddrive or incompatibility with a particular newer piece of hardware such as NIC or modem etc, and the maker's website indicates a bios update is available to address the problem then you should consider the risks/benefits. If a bios flash goes wrong you can completely trash your motherboard.
If you still want to proceed with this exercise then start by downloading Everest Home Edition from lavalys.com. Instal and run it and it will give you info on your system components including motherboard model and bios version. Once you have that info you should carefully research bios updates from the motherboard manufacturer. Flashing the bios is done using a bootfloppy that has to contain both the flash utility and new bios file. If any power failure or surge or error occurrs during the flash process, you're toast. The motherboard may or may not have a jumper that needs to be moved to "Unprotect" the bios so that you can perform the flash.
You will also be given an opportunity to save a backup of the original bios. Do so. If the new bios doesn't work properly you should be able to re-flash back to the old version.
I repeat. Unless your system has a problem that can only be resolved by a bios update then DON'T DO IT.
Another solution
Determinine Your Current BIOS Version
You can find your motherboard's BIOS version number on the POST screen. Restart your computer. As soon as you see the Biostar bootup splash screen, press TAB, this will reveal the POST screen (if you don't see the splash screen at all, it is okay. The version of BIOS you have most likely doesn't have the splash screen). Then immediately press PAUSE/BREAK key to suspend the boot process. You will see a screen similar to the one below:
post_sml.jpg In this example, the BIOS version is VIT0312F.
VIT = Model number
0312 = BIOS date
F = No splash screen
three_bluedots.gif Updating BIOS
All modern Biostar motherboards feature the Flasher technology for easy BIOS updating. If you have a legacy board, please download the Award flashing utility and follow the instructions in the README.TXT file instead. The procedure below does not apply to legacy boards.
Most motherboards' BIOS files have the BIN extension. Some do not (for instance, NCD1208.BSP, NHA0302.BF, etc). Regardless of its extension, after downloading the BIOS file is ready to use as-is. You do not need to do any kind of decompression or extraction.
Download the BIOS file (in this case, VIT0312B.BIN) then save it to a floppy disk. Restart your computer. Enter the CMOS setup by pressing at the POST or Biostar splash screen. Make sure the disk is in your floppy drive, choose "Upgrade BIOS" from the CMOS Setup main menu. The Flasher utility will automatically detect and highlight the BIOS file (in this example, VIT0312B.BIN) on the next screen.
Make sure the BIOS file (in this case VIT0312B.BIN) is highlighted and press Enter. Answer Y when prompted "Are you sure to flash?". After the flashing is done, reset the computer and enter CMOS setup again. This time choose "Load Optimized Defaults" from the main menu. Finally, hit F10 to save and exit.
BIOS update is complete.
three_bluedots.gif Legacy Motherboards
If you have a legacy motherboard which does not support the Flasher technology, please download the Award BIOS flashing utility and follow the instructions in the README.TXT file.
Aug 07, 2011 | Computers & Internet
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
HOW TO REBOOT
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro L300 Notebook
Computer is turned on, but screen is black
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Link to latest BIOS
Sep 21, 2010 | Acer Aspire One PC Notebook
I want to boot from usb flash drive. how can i do ?
Hi
Thank you for your query
Please try the following
1) Switch on PC
2) Press F12, del or the ESC key to enter setup
3) Go to advanced options and then choose boot options
4) In boot options choose USB peripheral to be set as first boot device
5) Save and exit from the BIOS screen
As the PC restarts make sure the USB flash drive is plugged into the PC
I hope this has been useful
Mar 12, 2010 | Biostar M7VKA Motherboard
Same problem
You need to flash the bios to a newer version for this cpu to be supported by your motherboard. Your descriprtion says asus so go to www.asus.com; click on the support link; lookup your specific board model #; select the operating system you are running. Download the latest bios file and follow the directions on the download site for proper flashing. Once you have flashed the bios everything should identify properly and allow you to continue setup. Hope this helps.
Jul 19, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Can't get into my computer because i don't know bios password
He's telling you to press F12 when you see the manufacturer's splash screen after you press the power button to be able to select the drive to boot from, it may say Optical drive or CD/DVD drive, etc.. This is a pretty common keystroke for most laptops.
Mar 18, 2009 | Toshiba Satellite A215-S7422 Notebook
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
Computers & Internet Logo
94 people viewed this question
Alun Cox
David Payne
David Payne
