Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Hothi i got a sony kv32fs120 the light on the front blinks 9 times thats all i am getting any help or ideas will be really grateful
  • 16 Answers
SOURCE: Standby Light blinks
it is an error code of the sony maybe there is a problem in it.
Posted on Apr 25, 2008
  • 4234 Answers
SOURCE: Sony TV stuck in stand by mode
Yes. The 9 blinks indiate a problem in the power supply area. I need to look up your specific model later today to get you the specific parts. If you are comfortable with soldering and working inside the set, you should be able to repair this yourself.
Stay tuned...
Dan
Posted on Jun 25, 2008
SOURCE: sony tv kv32fs120 has no power , 9 times blinks
Replace diodes D645, and D647 in standby power supply circuit.
Part# 6-500-567-01
Posted on Aug 07, 2008
SOURCE: no sound or picture
please see my above post.
Posted on May 02, 2009
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Posted on Jun 21, 2009
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
KV32FS120 blinks 4 times
4 times blink shows TV got problem in vertical deflection section and vertical out IC (IC561) either missing supply volts or itself bad.
Hope this info will help you if you are thinking to repair this TV.
Aug 30, 2009 | Sony Televison & Video
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
SONY KV32FS120
There are many different causes for 9 blinks on your model the best solution that i have for someone in your shoes is to replace the A board in the set. PN A-1302-981-A http://www.partstore.com/Part/Sony/Sony/A1302981A/New.aspx You may be able to find this board cheaper elseware. Let me know if you need more help?
Tim
Experttv@comcast.net
Sep 11, 2008 | Televison & Video
Apr 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Sony tv kv32fs120 has no power , 9 times blinks
Part# 6-500-567-01
Aug 29, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
309 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
