posted by 3axapu on Apr 26, 2008
is there a solution for garbled video on tc1100?
1 Other User Has The Same Problem
Comment by jyd777, posted on Jun 26, 2008
If i change the motherboard & TC1100 keyboard control KBD-BOX v2.2
will the same problem occurs again? i seldom use the keyboard.
Best Solution
posted on Apr 26, 2008
Sorry for the long reply, but I hope this helps.
You will need to replace the system board and the keyboard receiving bracket inside the computer to fix this problem.
I work at an institution that uses these laptops and we've seen this repair a lot... and I personally have a tc1100 that has gone through 5 system boards. HP has a new (slightly redesigned?) keyboard receiving bracket that helps (but doesnt always) remedy this problem. HP themselves told us that we need to replace the systemboard, keyboard bracket and keyboard when we see this problem on one of our machines. We replace them all the time at our repair shop and it is the only thing that consistently works.
Note: The system board's connections near the graphics controller can be severed (its a multilayered board so you might not be able to see it if you looked) when the keyboard can move inside the keyboard bracket thus causing your garbled / checkerboard screen.
For this reason, you can sometimes temporarily get it to boot correctly by tilting the screen towards you all the way before turning it on. We've also seen some cases where disconnecting the keyboard and trying to boot will work. You can use those ideas only as temporary fixes though, and I'm sorry to say that this problem will get progressively worse until you repair it.
Rating Locked! (?) 3axapu has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Compaq 348332-001 - Tablet system
Email this problem
Email this problem
Can you Help with these Graphic Tablets problems?
Compaq 348332-001 - Tablet system board w...
TC1100 garbled display
Hi, i'm currently living in... Answer This...
Repair Service
Find Graphic Tablet Repairman Near You:
