Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
When I open the lid to check the ink, the ink carriage does not slide so that I can remove it.
    President:
  • 2,571 Answers
If the printer is switched on, when you lift the lid, the print head should come to a halt in the center position.
If this is not happening, here is the link to download your guides/manuals http://www.kodak.com/global/en/service/publications/urg01062toc.jhtml?pq-path=12666/15387
Posted on Aug 05, 2010
I am low on ink and when I open lid to replace cartridge I get a screen error "Close The scanner unit" I have looked adjusted everything and re-started unit. Cannot clean or get to ink.
try this....Remove the old ink cartridge and install the new ink cartridge.
  1. Make sure the printer is turned on. ...
  2. Open the top cover of the printer. ...
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage...
  5. if this does not work go to this link it might help you out.....
How to replace cartridge Google Search
Oct 23, 2017 | The Office Equipment & Supplies
Que voy a fotocopiar algun trabajo documento. etc. y en la pantalla de la multifuncional dell a940 me aparece hardware error 0502 y tampoco puedo imprimir trabajos del computador
Hello
1. Ink cartridges lids are open which is not allowing cartridges to move freely. 2. Ink cartridges carriage will not move from its original position(left) when front cover is opened 3. Encoder strip is Dirty. 4. Encoder strip is Out of position.
Solution: 1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage. Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip: a. printer should be off and disconnected from power. b. open the front cover. c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely. d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod. e. Close the printer and try again to print.
4. Repositioning the Encoder strip. a. Remove the power cord from the printer. b. Open the front cover. c. Gently slide the ink cartridge carrier to the middle of the printer. d. Gently move the top part of the printer belt to the right. e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier. f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly. g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip. h. Once the encoder strip has been re-seated, close the scanner lid. i. Re-connect the power cord to the printer and try again to print.
Hope it will helps if so do rate the solution
Dec 20, 2010 | Dell A940 All-In-One InkJet Printer
I want to change my black ink cartridge and never do that !
Open the printer lid and you should see a carriage slide over with the ink inside. Remove the black ink by pulling it out followed by inserting the NEW ink cartridge in that same spot. Close the lid and your printer will run through a cycle and alignment page.
Dec 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Dell 924 printer
There could be 4 possibilities.
Solution:
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Carrier stall.
Solution:
Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Clear the carrier jam
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
Dell Printer carrierjam
Solution:
Aug 31, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge stall message
Solution:
Apr 07, 2008 | Dell 922 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
