Question about Bosch Dishwashers
My dishwasher will not drain but you can hear the pump running
  • Bosch Master
  • 17,130 Answers
If you hear the pump trying to do the job but with no result then you must not strain the washer. First of all shut off and get access to the drain, open out the hose and fittings connected to the pump and check for accumulation of waste/dirt. this could have cclogged up the pump. So remove and back flush or clean .Use a jet hose or ari hose to clear out the dirt and confirm the passage. The replace the pump and check out. I am sure it must work. Good day
Posted on Aug 05, 2010
Im getting an error of E24? what is this and how to fix
this is usually a drain problem. was disposer replaced? remove knockout. can you hear drain pump motor running? check filter and check valve. if drain pump is running and drain hose is not plugged, install new drain pump.
Nov 29, 2014 | Bosch SHE7ER55UC Dishwashers : Built in...
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
Intake / drain does not drain
verify you hear the pump running when it is supposed to be draining. If you don't hear the pump running, then you probably need to have a service person come out.
If you can hear it running, then then check the drain hose going to the kitchen sink drain if that is where it drains to. I have seen it where the rubber drain hose was left too long and when the dishwasher was push into place, it kinked the hose, preventing it from draining.
Mar 26, 2011 | Miele Incognito G818SCVi Built-in...
If you can close the door, turn the control to drain and, can hear the motor running; you have a clog under the pump screen in the back of the Dish Washer preventing the pump impeller from turning
if you hear nothing: reset the house circuit breaker.
to fix: while the DW is on turn off the DW house circuit breaker then remove the pump screen and, remove the broken glass etc. from the pump then: repower and, test.
May 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
I have a dishwasher model esd300 It is not draining after a full cycle runs. Any suggestions?
drain pump could be bad
the drain position of the timer switch could be bad
Do you hear the drain pump trying to run?
Oct 27, 2009 | Dishwashers
Whirlpool dishwasher won't drain? Model#DU5000xw
When it is suppose to be draining, do you hear the pump running.
If not, then the pump or controller/timer is bad. If the controller is sending power to the pump and the pump doesn't run, it's the pump. If no power is getting to the pump, then the controller is bad.
You'll need a voltmeter and know-how to diagnose this electrical problem. This is high-voltage power with water in the area. So please don't try to use a voltmeter unless you are confident of your skills.
If you do hear the pump, then the drain valve (solenoid) is the problem.
The solenoid valve and the pump are all underneath the unit. Accessibility from the front, bottom panel.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | KitchenAid Dishwashers
Water does not drain
For the water to drain, the controller must send power to the water pump and the solenoid (drain) valve.
If you hear the pump running when it should be draining then the controller and pump are working and the solenoid is bad (usually the case).
If you don't hear the pump running during the drain mode, then either the pump is bad or the controller is bad (not sending power to the pump).
Also, check that you do not have debris inside the dishwasher where the water drains. This is around the spindle in the bottom of the dishwasher cabinet where the spray arm comes up.
Oct 13, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher is full of water cannot drain
If you can hear the pump running during a drain cycle then there may be something blocking the drain hose. A cherry pit for example. Look underneath the DW where the hose connects to the outlet of the pump. If you do not hear the pump running then it is the problem.
Aug 22, 2009 | Dishwashers
Maytag dishwasher won't drain water
It may be a water pump issue. You need to run it through a cycle and listen to hear if the pump is trying to run when it should drain. If you hear the pump running, but nothing is draining, you likely have a clog somewhere either going to or in the drain hose.
Nov 23, 2008 | Maytag Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
