Fuse seems to have gone so tv cannot switch on.
  • Televison & ... Master
  • 17,130 Answers
If you fuse had gone off then it is most possible that the set has a failure within, This can a short in the powerr supply section or the high voltage section. So first of all remove the back covers and use a multimeter to check on the power supply which could be swittch mode power supply. You must look for short in the surge protector, the filter capacitors, the rectifiers, teh main capacitors or the SM drives. If these are fine discconnect the HT side and switch on to confirm the power supply. If fine check on the HT for failure of the drivers/ capacitors in the section by a contiinuity, voltage test. Do it carefully, get help if not familiar. Good day
Posted on Aug 05, 2010
When I switch on the lights on the front flash on/off quickly but the machine does not power up. Fusboard seems OK?
sounds like a capacitor has gone! cheap to buy but a little tricky to fix if you don't know what or how to replace them. you tube it. Get a hair dryer n blow hot air into the air vents on the bottom of your tv for around 3/5 mins then turn your tv on again. it should work, but it also might be a dry joint on a circuit board!!
Jan 11, 2015 | Televison & Video
I have a Sanyo ds20424 the breaker in my house tripped and now the tv won't power on. It happened before and I took tv apart and got it to work again. Is there an internal reset switch? What could be the...
I don't think there is no reset switch inside the TV but may be FUSE blown deu to power intruption pls check the fuse and if it gone peplace the fuse with same rating
Aug 27, 2010 | Philips TP2784C TV
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Won't switch on
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
Jun 02, 2009 | Televison & Video
C21T7BA TV will not power up.
check the internal mains fuse usually connected to the mains lead via the on/off switch .good luck farr64
May 02, 2009 | Mitsubishi VS-60607 TV
Hi watching tv and it just switched off
first of all check out the tv power cord wire is it fine or seems like it got cut from some where or do you get any burning small from the wire.if this the case then repair that wire.if the wire is proper then try that wire in another electric outlet.if everything does not works.then is naturaLLY the internal board error.any of the capacitors or the ICs have gone short .the faulty 1 should be checked and replaced.
Nov 30, 2008 | Philips 42PF5421 42 in. LCD Television
Phillips 60PP920217F big screen TV
does anyone know why the picture does not come on .Is there any fuses that might of gone bad?If you know respond to this ?thanks
May 15, 2008 | Televison & Video
Power disconnectd when i switch on my TV
maybe the power regulator is damage or there some zener diode change value
Mar 27, 2008 | Philips 20PT6441 20" TV
Late turn on
seems like you are having some problems in the power section of the tv. they are either one capacitor gone bad or some of them gone bad. do you know how to check capacitor? if not just take it to a repair man. good luck
Mar 31, 2007 | Samsung TXJ1366 13" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
