Question about HP DeskJet 990cxi InkJet Printer
HOW DO I CLEAN THE PRINTER INK JETS? - HP DeskJet 990cxi InkJet Printer
    Brigadier General:
  • 10,406 Answers
When you installed the printer-driver from the CD-ROM that came with the printer, you also installed the HP Support Toolbox software. Run that software, and choose "cleaning cycle".
Posted on Aug 05, 2010
Printer prints every 2nd or 3rd line of a Word Document in pale gray ghostly way
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Nov 29, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Want to clean the jets of cartridge, help required
If you look through the printer maintenance functions of the printer folder in Windows, there should be an option to 'clean' the cartridges and their respective jets.
However, it's not recommended to do this too often, because just a few cleanings can deplete the ink in the cartridges.
If you have missing lines or jets aren't putting out ink across the whole printed page, then the cartridges may have to be replaced.
Feb 12, 2011 | HP PSC 2410 All-In-One InkJet Printer
Lexmark x125 prints blank pages.
The printer cartridge could be
1) Out of ink and need to be replaced/refilled
2) The jets at the bottom of the cartridge may be clogged
3) Their could be a bad connection from the cartridge to the pads on the flexible circuit board in the printer.
To try and clean the printer cartridge I have heated a wet paper towel in a microwave oven and set the ink cartridge with the jet are in contact with the hot towel. That sometimes will clear the jets. If you see ink on the paper towel the jets are flowing.
Run the printer software to run the cleaning program and see if you get black bars on the paper. If not there is either not enough ink or there is a connection problem. Sometimes the connection problem can be fixed using a cotton swab in alcohol to clean the contacts on the cartridge and the flexible circuit in the printer. Be very gentle if you attempt this cleaning.
Aug 28, 2010 | Lexmark X125 All-In-One InkJet Printer
Nothing showing up on paper yet printer showing enough ink.printer hasn't been used for a while.could the ink be dried up?don't want to get more ink if there is another problem.
Contact an ink seller, You need to flush the jets with a cleaning set of cassettes. Whilst you could try running a maintenance clean on it You may just compound the problem by pushing more coagulated ink into the fine jets
Often better to leave a printer on so that the ink is always warm. Not always convenient but saves many a printer
Please rate my help++++Thanks for using FIXYA
Jun 21, 2010 | Dell 725 InkJet Printer
Print has lines in it
Most probably you need to clean the ink jets.
Go to the Control Panel,
Go to Printers and Faxes
Right click on your printer
Choose printer preferences
Go to services or maintenance and choose either "service this device" or "clean the ink jets"
Jun 05, 2010 | HP Photosmart C4580 All-in-One - InkJet...
The jets are constantly needing cleaning...
Either you're using a low grade ink to refill the cartridges or you're not using it enough to keep the head clean. If the ink is allowed to dry on the print head, simply running the "Clean print head" function doesn't always get the dried ink loose. Remove the cartridge and CAREFULLY, clean it with damp toilet paper. Only go ONE DIRECTION when cleaning. SIDE TO SIDE. When it looks clean, check carefully for any left over fuzz. You can also clean the wiper inside the printer with a damp cotton swab.
May 03, 2009 | Epson Stylus Photo 925 InkJet Printer
Clogged ink jets prevent printing any thing. how
You can try to use the software the came with your printer on your computer to clean the heads. If that doesn't work then you will need to buy new ink cartridges.
Mar 23, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How do you clean the ink jets
if it isn't broken, don't fix it. I would leave well enough alone until the printer starts giving you trouble.
Mar 13, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP DeskJet 990cxi InkJet Printer Logo
153 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
