My washing machine will not empty of water and this is preventing it from spinning.how do i empty the water via pump filter as i have no manual and it will not let me download one.please help!
    Sergeant:
  • 216 Answers
This is could be caused from several issues. First I would try changing cycles on the timer to another spin cycle to see if that let the washer drain. Some times the timer malfunctions and doesn't allow the washer to spin. If this doesn't work and you can hear the motor running then you could have a broken belt or bad clutch or a wig wag (electric solenoids that operate the transmission.). The easiest way to empty the washer if it's located near a floor drain is to remove the drain hose from the drain and lay it on the floor near the drain. The water will run right out of the machine. If you not near a drain then you can use a Wet / Dry Shop Vac, remove the paper filter from inside the Shop Vac and then your ready to vacuum out the water. You will need to empty the vac several times.
Or you can use a garden hose and siphon the water out by place in one end in the washer and the other end outside or near a drain, You will need to **** on the end of the hose that's near the drain or outside. This will almost guarantee you a mouth full of laundry water so be careful if you try this.
Posted on Aug 05, 2010
My machine a Bosch excel vario keeps displaying E18 and flashes and keeps pipping I canot get the door open tried two washes
E18 indicates a time out draining.
I'm assuming it's stopped full of water.
Put the machine on spin only and see if it empties and spins.
After that you'll need to check it over.
It's very likely there is a blockage preventing the machine draining.
It can also be a faulty pump or control board but this is less likely.
It's a lot of work but try the following.
Check the drain hose where it connects to the house drains.
If onto a connection, take the hose off and check both for a blockage.
This is normally under the sink.
If ok, you'll need to manually remove the remaining water from the machine.
Put a shallow dish in front of the filter/pump cover. (Bottom front of the machine)
Slacken the cap a little to drain the water.
If there is a draining tube, use that to empty the water.
Tighten the cap to stop the water when you need to empty the container.
(If you pull the machine out and tilt it rearward, you can get a larger container in place for a while).
Once the machine is empty of water, take the cap off.
Clean out any debris in there.
Once cleaned out, take the laundry out of the machine.
With the cap off, put the machine on spin only. (If it resets).
Listen at the open filter to see if the pump is running.
(You should see the pump impellor rotating)
If the pump isn't running, let me know.
If the pump is running, refit the cap and try the machine again.
Good Luck
Feb 16, 2015 | Bosch Washing Machines
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Hoover Zodiac 12 that won't spin.
possible filter blockage, or the pump has failed/seized, machine CANNOT spin while it CONTAINS WATER, the door interlock will not open for the same reason,WATER in drum.
manually drain excess water into a bowl now
1 clean filter, 2 check pump for objects that prevent impeller working may still need pump if seized
Jun 12, 2009 | Washing Machines
The washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
May 29, 2009 | Kenmore Washing Machines
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Not spinning
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
