I have an extremely noisy fan on my LP mini tower cpu fan. It is a model shipped in yr 2000 but works phenomenally well excepting the horrible noise. I looked at the fan and it appears to be mounted with special fasteners so that I would need instructions on its removal and replacement unless there is a simpler solution - please help, thank you!
  • 1 more comment
  • henry897 Apr 27, 2008
    Thank you for the time and energy into helping with the problem. The "LP" is exactly what was on the computer tower identification sticker, I do not know what it stands for. I will type in all the sticker info as it is. It states:
    Serial # 0020643131 model LP select mini tower KAD
    It, is a "Gateway" computer shipped in 2000.
    Now that I have clearly defined the problem, does anyone know where I can get instructions on changing out this fan for a new one? Thanks to everyone who is making this possible.
    Thank you so very much! After the many hours on the internet resulting in frustration, even from the "helpful" techs at "Gateway",
    it is wonderful and refreshing to have found this pragmatic site with direct, useful, and rapidly delivered information.
    Thanks again to the individual who answered this query, and all participants in this educational endeavor!
    best for nonce,
    moi'
  • Anonymous Mar 24, 2009
    wondered what makes my p3 cooling fan
    so noisy its a deskpro compaq 815 mobo
    Genius:
  • 3,587 Answers
Nope..and you'll need a new fan..what's LP? did you mean HP?
Posted on Apr 26, 2008
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    ahh..it's a Gateway...those fans are mounted in the panel inside the unit. simply remove the sliding side panel(usually with screws or thumbscrews on the back).
    then, disconnect the fan power cable from mother board..
    the fan will be mounted with plastic 'ears' that need to be compressed inwards(towards the body of the fan) and then removed..it comes out as all one assembly.
    On some Gateways, you'll need to remove the microprocessor cooling assembly first, which is simple by unscrewwing it from the mother board.
    Depending on the model you have, this should take around 20 to 30 minutes..max..
    remember to plug in the fan cable again, once it's installed.
  • Patrick Michaels
    hope it works forya..
    and thanya for using fixya
How to fix noisy fan?
look for the fan opening, get a can of air and blow it threw the fan vent, while the computer is off, than let it set for a few minutes than start it back up, if fan is still noisy, than you need a new fan installed.
if you want to do the work yourself you can do it your self. now if you dont want to try it than i have a few place to take it for service.
acer authorized dealer, best buy, or if you have a friend that you trust that will fix it for little to nothing except cost of parts, the fan part for the acer should be around 7-10.00 dollars + labor + shop fees.
www.youtube.com/HOW TO FIX LAPTOP CPU FAN
/how disassemble acer aspire laptop
/how to replace CPU fan acer laptop
/how to oil cpu fan for acer laptop
Apr 22, 2015 | Acer Aspire Computers & Internet
How do I control CPU fan speed on an Acer G45T/G43T-AM3?
Some gamer or extreme motherboards have this feature, but I doubt ACER does. Try blowing out dust with canned air. This really works for me. I have an older machine, and I live in dusty Vegas so I know what you mean.
The other solution is to look for a bigger and quieter heatsink / fan.
Oct 25, 2012 | Computers & Internet
Pcg-3c2l system fan extremely noisy
Your fan is about to go out. It will have to be replaced. Once the fan goes out your laptop will run hot and shut down without notice. To replace the fan calls for disassembling your laptop. Get a quote from your local computer shop, then try the guys at:
http://www.generalsystemsconsulting.com
They will repair it and ship it back by Fedex or UPS and beat most quotes including the shipping charge.
Mar 22, 2012 | Computers & Internet
Cpu fan noise
Hello
You need to open the case and have a look at the fan.Chances are there is a wire rubbing the blades.Or alot of dust on it.Blow it clean with a can of compressed air.
If you need a new fan you can contact the processor manufacturer.Intel or amd.Or take the fan to a computer shop or appliance store and match it up with a new one.
Nov 02, 2011 | Averatec D1133 (D1133AH1E-1) 18.4 in. PC...
Laptop heats up and the fan is extremely noisy. its almost impossible to place it on my lap while working due to the heat.
This indicates that the fan is faulty and possibly the heat sink is clogged with dust.
A noisy fan could have a worn bearing, I suggest you replace the fan.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 16, 2011 | HP Pavilion dv4-1140go Laptop
NO DIAGNOSTIC LEDS LIGHT UP
This problem has repeatedly been reported with this model and the 4800. People will tell you it's the power supply, motherboard and CPU. It is none of those. Your CPU cooling tower has been jarred loose. Dell made these things way too big, and as a result a simple bump to your case can make everything go crazy. Remove your fan shroud, then the fan then the cooling tower, cleaning each as you go.
Now remove the large cooling tower. Remove, clean and reseat your CPU, add NEW thermal paste and reassemble everything and keep the PC on it's side. The system should now be able to reboot. In extreme cases of jarring such as the PC has been dropped etc, your motherboard may have been damaged. In this situation it is best to buy a new motherboard and transfer all your components to the new board. So far, I haven't had to do this though. Most of these PC's come back to life easily with the steps I just mentioned above.
Aug 30, 2010 | Dell Dimension 4700 PC Desktop
PC is LP Mini Tower TB3 Essential 450. PC is
If the operating system is Windows XP or 2000, then restart the computer, press F8 before the loading screen (after BIOS) and select Safe Mode. Then login to the administrator's account. Click 'Start', and then 'Run'. Type "control userpasswords2" without quotes and press enter. Find your account on the list, click reset password, enter a new password, shutdown and switch back on.
Jan 10, 2010 | Gateway Essential 400 PC Desktop
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
My computer has always been extremely noisy.
has the cooling fans been cleaned lately?PC's shouldn't be noisy to the point you're asking for advise about it. Is it a grinding noise, a clicking noise..more info plz.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
221 people viewed this question
David Payne
David Payne
