Question about Whirlpool Duet GHW9150P Front Load Washer
Keeps throwing an F2 code - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
I have a 2005 dodge Durango 5.7 hemi I am being told that the fuel filter isn't serviceable... I have ran codes and it keeps throwing a fuel code but fuel pump is working as it should. Truck will sputter...
I have ran codes and it keeps throwing a fuel code but fuel pump is working as it should.???? What code ??? P0 what ? Can't help without knowing code .
May 16, 2018 | Dodge Cars & Trucks
I have code 50 showing. I’ve followed the steps to reset it, but it keeps throwing the code. Any ideas? I’m just an owner of a trailer and not a mechanic.
If it keeps throwing the code you will need to get someone to trace the fault back. There must be something else in the system that is tripping the fault code. Resetting the code doesn't fix the problem.
Apr 02, 2018 | Cars & Trucks
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE OVEN THROWS F2 AND F3 CODES SOME TIMES WORKS FOR 45 MINUTES BEFORE CODE
The F2 code means that the oven overheated by at least 100degrees(a bad sensor will cause that)
the F3 means that the oven sensor is shorted,so both of them are consistiant with defective oven tempature sensor and the sensor should be replaced.
It is located in the oven baking chamber and can be replaced by unscrewing the screws from the bracket at the end of,pull it out unplug it,then reverse that process to install the new one.
With 2 different codes pointing to a bad sensor its apretty safe bets its bad.
GENE
Oct 10, 2011 | Ovens
My jeep keeps throwing a 1281 code I have changed thermostst twice 195 deg I put a new coolant temp sensor in also but still keeps throwing this code
CODE PO1281 ENGINE IS COLD TOO LONG.INSPECT FOR LOW COOLANT LEVEL OR AN INCORRECT MIXTURE.USE CODE SCANNER TO ERASE CODE.AFTER YOU MAKE A REPAIR ON ENGINE YOU NEED TO ERASE CODE OR IT WILL KEEP TURNING ON.
Apr 25, 2011 | 2003 Jeep Wrangler
Dodge Ram 3500 Diesal 2004 keeps throwing code
contact your dealer service department with the code and they should have no problem hooking you up with the problem
Dec 29, 2009 | 2004 Dodge Ram 3500 Truck
Error code F2 keeps beeping! Will not reset. Any
thats the oven sensor , replace the sensor and your good to go
Jun 17, 2009 | GE JKP27 Electric Double Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
