Question about Toshiba E-Studio 3511 Color Copier
My 3511 is posting the error code CA10. How can I fix this?
  • 776 Answers
The error code means that Polygonal motor is having a fault. The polygonal motor is not rotating normally.
please refer to the manual for further troubleshoooting:
http://www.gioffice.com/Op_manuals.htm
Posted on Aug 05, 2010
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
Toshiba e studio 3511 F120 error need to know what this error is and how to fix?
F120] Database abnormality
(1) Rebuild the databases. (Perform 08-684.)(2) If the error is not recovered, initialize the HDD. (Key in "2" at 08-690.)
Any money the HDD is duff. Srri
Apr 28, 2011 | Toshiba E-Studio 3511 Color Copier
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Error code "CA10"
Hi how are you this is jack .....(jack_pak@hotmail.com).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
The display on my ST-CA10 is out of function
have u solved the display problem?
i have the same problem.
tell me please, if you solved it...what should i do to make it work.
thanks
lin-q@hotmail.com
Jul 30, 2010 | Technics Audio Players & Recorders
I need to how what ERROR CA10 in a Toshiba e-600 mean.
problem in laser unit.most popular in polygun motor
May 24, 2010 | Toshiba E-Studio 3511 Color Copier
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
F 105
How do u get in service mode on a toshiba 3511
Nov 06, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
CA10
It's a problem in the laser unit...(polygonal mirroe)
You need a technician for this one...
Jul 11, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Color Copier Logo
50 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
