Question about Star trac ST Fitness 8920 Treadmill
ST Fitness 8920: unit won't work: display says scheduled maintenance - see manual however no info in manual. Tried pushing hard reset button next to on switch to no avail.
Press (incline +) and (speed +) on the control board at the same time for a few seconds.
Posted on Jan 21, 2011
  • Anonymous Nov 12, 2015
    Thank you Thank you Thank you!!!
How reset oil change light 2011 charger
Your vehicle is equipped with an engine oil change
indicator system. The "Oil Change Due" message will
flash in the EVIC display for approximately 10 seconds
after a single chime has sounded to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you cycle the ignition to the ON/RUN position. To
turn off the message temporarily, press and release the
MENU button. To reset the oil change indicator system
(after performing the scheduled maintenance), perform
the following procedure:
1. Without pressing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Source: Owner's Manual page 293
Dodge Charger Owners Manual
Oct 04, 2013 | 2011 Dodge Charger
Reset oil change indicator on 2011 Dodge Charger
within 10 seconds.
OFF/LOCK position.
Oct 22, 2012 | 2011 Dodge Charger
How do I reset maintenance light
To reset "Maintenance Notice" on the display, turn the ignition key to ON, with engine off. Select the "Maintenance Schedule' key by using the button to right or left. Using the button select the "Reset" key and push the "Enter" button.
May 17, 2012 | 2008 Nissan Altima Hybrid
Quantum II Horizon fitness treadmill Electric motors won't function
Dear Sir:
pLEAse lube in according with the instruction manual maintenance you can have deck belt worn 2) Inspect the drive belt and replace it 3) Measure the input voltage motor, if there are voltage motor need repair or replace 4) test the output voltage from main motor board, if there are NOT the board is faulty.
sincerely. God bless you
Apr 29, 2012 | Exercise & Fitness
How do I reset my maintenance required light on my 2009 Avalon?
SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oct 19, 2010 | 2008 Toyota Avalon
I have a 2009 2.5sl Nissan Altima. Can I manually reset the master warning light on the light.I just changed the oil that is the reason that it came on.
May 27, 2010 | 2008 Nissan Altima
Maintenance needed comes up on the display for engine oil. It was changed 1500 miles ago and that is what the maintenance display shows
i found this on a Murano forum, so i cannot validate whether or not it works.
-To reset the maintenance notice on the display, turn the ignition key to ON, with engine off. Select the "Maintenance Schedule" key by using the button to right or left. Using the button select the "Reset" key and push the "Enter" button.-
Hope this helps,
matt
Oct 08, 2009 | 2006 Nissan Murano
Kitchenaid hood wont allow reset of "C"
Try presing the "+" button for four seconds instead...
Mar 20, 2009 | KitchenAid KICU265HSS Kitchen Hood
Star trac ST Fitness 8920 Treadmill Logo
459 people viewed this question
Top Star trac Exercise & Fitness Experts
Tom Chichester
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Star trac Exercise and Fitnes Expert? Answer questions, earn points and help others
